help with mpfi
Old Feb 29, 2004 | 09:04 AM
itsalan's Avatar
Default help with mpfi
i did the dpfi to mpfi on a 88 crx with a zc motor. The car starts, idles fine but has a rev limit at 1500rpm. the ecu is coding for 4, 10, and 14. i've double and triple checked the wiring, even redid the ecu wiring. anybody have a clue what could be wrong?
Old Feb 29, 2004 | 11:47 PM
itsalan's Avatar
Default Re: help with mpfi (alan909)
bump?
Old Mar 1, 2004 | 04:03 AM
Fobtions's Avatar
code 4- ckp sensor "crank position sensor" recheck your distributor plug pin locations.
these next two are easy and obvious.
IAT "intake air temp" its the sensor that is on the #1 cylinder intake runner, usually white.
IAC " Idle air control" is the thing at the back of the intake manifold with two coolant line running into it.
you have em both switched.
Old Mar 1, 2004 | 05:32 AM
Bee17hatch's Avatar
Default Re: help with mpfi (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">code 4- ckp sensor "crank position sensor" recheck your distributor plug pin locations.
Old Mar 1, 2004 | 09:56 AM
itsalan's Avatar
Default Re: help with mpfi (Bee17hatch)
switched the plugs, got rid of code 14, but its still coding 4 and 10
thanks for the help so far
EF4lyfe
Sep 20, 2004 12:00 PM
vultron
Dec 13, 2003 09:45 PM
shorty91
Jun 27, 2003 11:18 AM
FourthGenHatch
11
Apr 27, 2003 04:34 PM
DLB1994
Aug 18, 2002 03:29 PM
