Which camshaft specs are best for TURBOCHARGING.
Old Feb 29, 2004 | 09:03 AM
C-Zero's Avatar
Default Which camshaft specs are best for TURBOCHARGING.
I need help picking a Camshaft for my Turbo build.
1. Duration - IN. 295 (12.5 lift mm) EX. 285 (12.0 lift mm)
2. Duration - IN. 300 (12.5 lift mm) EX. 290 (12.0 lift mm)
3. Duration - IN. 305 (12.5 lift mm) EX. 295 (12.0 lift mm)
Modified by Soichiro-Honda at 12:54 PM 2/29/2004
Old Feb 29, 2004 | 09:54 AM
C-Zero's Avatar
Up
Old Feb 29, 2004 | 11:34 AM
C-Zero's Avatar
Advance.
Old Feb 29, 2004 | 11:38 AM
infinatenexus's Avatar
How about the specs for the valve overlap?
Old Feb 29, 2004 | 11:44 AM
C-Zero's Avatar
You control overlap with adjustable cam gears (Correct me if I'm wrong.)
Old Feb 29, 2004 | 11:50 AM
AB16A2T's Avatar
Default Re: (Soichiro-Honda)
I would think you would want cams that minimize overlap, so you can use the cam gears for other things. You would have more adjustability that way.
Old Feb 29, 2004 | 11:52 AM
ZoRG's Avatar
I know this is not to what you are asking but speak to these guys http://www.m24x.com they know their stuff.
Old Feb 29, 2004 | 11:55 AM
C-Zero's Avatar
It's for a K-series engine. I'm doing research for my k24. and I need a camshaft that would work perfect on a fully built engine for optimum power.
Old Feb 29, 2004 | 12:30 PM
ZoRG's Avatar
Ask them, they can problably make one for you.
Old Feb 29, 2004 | 01:31 PM
hpfsi's Avatar
Default Re: Which camshaft specs are best for TURBOCHARGING. (Soichiro-Honda)
I wouldn't use Toda vtec killer cams for turbo apps if thats what you're asking about (they match the specs you posted). They have no primary or secondary lobes (or rather the primary/secondary lobes are larger than most vtec lobes), which means your compressed air would most likely find a quick route out the exhaust valves due to the overlap.
Old Feb 29, 2004 | 01:37 PM
C-Zero's Avatar
Default Re: Which camshaft specs are best for TURBOCHARGING. (hpfsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hpfsi &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't use Toda vtec killer cams for turbo apps if thats what you're asking about (they match the specs you posted). They have no primary or secondary lobes (or rather the primary/secondary lobes are larger than most vtec lobes), which means your compressed air would most likely find a quick route out the exhaust valves due to the overlap.</TD></TR></TABLE>
I just need opinions for best one for turbo, I dont need opinions on not to use them.
Rember its at a certain lift. (thanks anyway)
Thats not true. Angela Proudfoot uses VTEC killers on her car and shes running 8 second with turbo, and crane camshaft
Modified by Soichiro-Honda at 2:50 PM 2/29/2004
Old Feb 29, 2004 | 02:02 PM
hpfsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soichiro-Honda &raquo;</TD></TR><TR><TD CLASS="quote">
Thats not true. Angela Proudfoot uses VTEC killers on her car and shes running 8 second with turbo, and crane camshaft </TD></TR></TABLE>
Toda measures duration at zero lift btw. Most people that are building engines like Angela Proudfoot's aren't coming on here asking about using vtec killers on turbo'd engines, hence my recommendation not to use them. I didn't know you were building this type of motor. Could you give us a general plan/goal for the engine? For any other use I would like to see how you can build boost with a cam like this. And I would be curious as to what type of duration those crane cams are too.
Old Feb 29, 2004 | 02:20 PM
SOHCArchangel's Avatar
typically for a boosted app the cam you really want to worry about is the exhaust cam,
in my experience the ones which work better tend to be high lift low duration on the exhaust side, on the intake side you can run whichever suits you
imho
from your chioces i would pick #1 ex for the ex and #3 in for the intake
Old Mar 1, 2004 | 05:21 AM
ZoRG's Avatar
Default Re: Which camshaft specs are best for TURBOCHARGING. (SOHCArchangel)
Why don't you just run the crane setup? They have a special roller cam for turbo.
C-Zero's Avatar
ITS A K-series motor.
Old Mar 1, 2004 | 05:40 AM
ZoRG's Avatar
Crap sorry, forgot that
Old Mar 1, 2004 | 05:55 AM
tgreaves's Avatar
Default Re: (ZoRG)
Dont the K series motor automatically adjust the intake cam degrees.. I know the K20 civic si motor does but I dont know it all K's do it..
Old Mar 1, 2004 | 05:56 AM
C-Zero's Avatar
with VTEC killer the I in the VTEC is gone.
Old Mar 1, 2004 | 06:05 AM
C-Zero's Avatar
Never mind I changed my mind about this, I'm going to incorporate VTEC.
Old Mar 1, 2004 | 08:43 AM
Killa's Avatar
Go with a lot of lift and find out the cam's valve overlap, once you know that try to get the lobe centers to around 112* via adjustable cam gears.
Paul
Old Mar 1, 2004 | 09:14 AM
kpt4321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hpfsi &raquo;</TD></TR><TR><TD CLASS="quote">which means your compressed air would most likely find a quick route out the exhaust valves due to the overlap.</TD></TR></TABLE>
And that's a bad thing?
Old Mar 1, 2004 | 09:30 AM
C-Zero's Avatar
Default Re: Which camshaft specs are best for TURBOCHARGING. (kpt4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">
Its a good thing. Ill get a less agressive cam and have VTEC kick in at 3500.
Old Mar 1, 2004 | 09:47 AM
tgreaves's Avatar
Its a good thing. Ill get a less agressive cam and have VTEC kick in at 3500.</TD></TR></TABLE>
He means the overlap is a bad thing.. Some of the boost charge will come in the intake valve and go right out the exhaust valve until the exhaust valve closes..
Old Mar 1, 2004 | 09:56 AM
C-Zero's Avatar
Its a good thing. That how ALS works. Inertia will pull air in.
Old Mar 1, 2004 | 10:04 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soichiro-Honda &raquo;</TD></TR><TR><TD CLASS="quote">Its a good thing. That how ALS works. Inertia will pull air in.</TD></TR></TABLE>
I can see that but does it still have a positive effect on a turbo car.. Sure its pulling air in but the turbo will force the air in by itself, Wouldnt that create something like a boost leak then?
