will tranny leak if the axels are not in?
Old Feb 29, 2004 | 08:47 AM
H22A EG6's Avatar
Default will tranny leak if the axels are not in?
just as the title says!
Old Feb 29, 2004 | 09:13 AM
dfm's Avatar
dfm
nope, the axels come apart from a inner cv joint, that stays in the box, and keeps fluid in
Old Feb 29, 2004 | 09:21 AM
b16hybridsol's Avatar
Default Re: (dfm)
i concur, my b16 del sol and h22 teg both leaked when i took the axles out, the inner and outter joints are considered parts of the axles, it depends on the angle you've got it jacked up at also
Old Feb 29, 2004 | 10:53 AM
dfm's Avatar
dfm
i duno then mate, on the 2 ludes ive had, manual and my auto, when the shaft is pulled out the inner cv it was just grease that came out, not tranny fluid
Old Feb 29, 2004 | 12:37 PM
satan_srv's Avatar
Default Re: will tranny leak if the axels are not in? (H22A EG6)
why would you pull apart the cv joints??!
If you pull the splines out of the diff, yes tranny fluid will come out. If you turn it on it's side...you you can pull the axles while the tranny is in the car and nothing if any will leak out.
Old Feb 29, 2004 | 01:10 PM
damntired42's Avatar
only a small amount of fluid will come out when half shafts removed, but it wont drive.
Old Mar 1, 2004 | 11:07 AM
H22A EG6's Avatar
Default Re: will tranny leak if the axels are not in? (damntired42)
reall i was planing on driving it with out the half shafts
i was talking about the whole axle shafts not the cv thx
Old Mar 1, 2004 | 12:43 PM
how are you planning on getting power to your wheels?
Old Mar 11, 2004 | 01:37 PM
H22A EG6's Avatar
Default Re: will tranny leak if the axels are not in? (b16hybridsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">how are you planning on getting power to your wheels?</TD></TR></TABLE>
are you kidding me it was a joke...
Old Mar 11, 2004 | 01:47 PM
v4lu3s's Avatar
RTFM
if the tranny is not level oil can pour out of the holes for the axles.
Old Mar 11, 2004 | 02:32 PM
Honda Sport's Avatar
Default Re: will tranny leak if the axels are not in? (satan_srv)
[QUOTE=satan_srv]why would you pull apart the cv joints??![QUOTE]
exactly. why would you pull the cv joints apart? maybe to replace the bearings but you don't need to pull apart the cv joints to pull out the axles. and yes, it'll leak tranny fluid if the whole axle is removed from the transmission.
Old Mar 11, 2004 | 04:15 PM
Sampsonite987's Avatar
Default Re: will tranny leak if the axels are not in? (Honda Sport)
It will leak a little when you pull out the axles, dont pull the cvs apart, thats even more of a mess. If you tip the tranny it will pour out.
blazinsii
Oct 30, 2005 05:05 PM
97Alex
Mar 20, 2005 02:36 PM
E-Rok
Jul 30, 2003 03:11 PM
EVIL_AWD
May 24, 2003 06:28 PM
EVIL Hx Coupe
17
Nov 1, 2002 01:56 PM
