MSD wiring problem, throwing a code 15 (Ignition output signal) help?
Old Feb 29, 2004 | 04:45 AM
djnikko's Avatar
Default MSD wiring problem, throwing a code 15 (Ignition output signal) help?
i have just wired in my MSD 6 AL to my CRX 89 ZC however im getting a code 15 when trying to start it. It is a possibility that i knocked the rotor arm out and the ignition timing is 180 degrees out, could that cause a code 15?
any help would be great
thanks
Old Feb 29, 2004 | 02:20 PM
djnikko's Avatar
Default Re: MSD wiring problem, throwing a code 15 (Ignition output signal) help? (djnikko)
bump!
Old Feb 29, 2004 | 07:40 PM
boostn420's Avatar
how exactly did you wire it, does the tach still work?
Old Feb 29, 2004 | 10:19 PM
djnikko's Avatar
Default Re: MSD wiring problem, throwing a code 15 (boostn420)
the engine turns but doesnt spark so not sure about the tacho... i wired it using the diagram from msd, internal honda coil.
Old Mar 1, 2004 | 06:48 AM
djnikko's Avatar
Default Re: MSD wiring problem, throwing a code 15 (djnikko)
engine turning over sounds fine but just doesnt spark and i get a code 15, has no one had this before?
bump!
djnikko
Mar 1, 2004 09:12 AM
