best bushes for crx
Old Feb 29, 2004 | 02:42 AM
NOSED_CRX_VTEC's Avatar
Default best bushes for crx
What poly bushes do you guys fit to you crx and civic?
Thankss
Old Feb 29, 2004 | 03:20 AM
^jefs0ng's Avatar
Banned
ES bushings
Old Feb 29, 2004 | 03:31 AM
jc836's Avatar
Default Re: best bushes for crx (NOSED_CRX_VTEC)
There are several schools of thought on this. We used ES for the rear trailing arms and LCAs. Those along with ES Sway Bar bushings and end links at both ends work very well together. If you are lowering the car consider either the SPC or Ingalls rear upper adjustable arms (not allowed for SCCA Improved Touring) with poly.
The difference as best I understand it between ES and Prothane is a slight difference in the Durometer (hardness) of the poly and the way you install them. Prothane includes the sleeves for several locations while ES requires you remove only the rubber and save the pins for the TA donut bushings. Check both online to see what they offer.
It is my opinion that you do not need the full "Master Kit" from either and that using rubber bushings up front is sensible-mainly if the car will be street driven. Another thing-poly WILL squeak and it can be bothersome. Some racers are using the Mugen bushings sold by OPM in the TAs and those work very well compared to stock. DO NOT replace the shock bushings with poly unless you are building an all-out track car.
Good luck
Old Feb 29, 2004 | 03:46 AM
silverCRXTC's Avatar
Default Re: (^jefs0ng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^jefs0ng &raquo;</TD></TR><TR><TD CLASS="quote">ES bushings </TD></TR></TABLE>
a pain in the *** but worth it
koshir
Apr 19, 2006 11:18 PM
ED9man
45
Mar 15, 2006 11:49 AM
vodavi6346
Jul 24, 2004 10:16 PM
ironchef25
12
Jan 20, 2004 05:33 PM
Jdm93civic
Aug 15, 2003 05:35 AM
