how do i remove the rotor?
Just drill out the screws, like the above is stated, the wheel keeps the rotor on, the screws are insurance, but i drilled them out back in feb 03 and i have yet to have any problem because there is no reason to really. It will just make ur life easier than impacting them out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh »</TD></TR><TR><TD CLASS="quote">probably have to use a hand impact driver too get the two phillips head screws out....</TD></TR></TABLE>
OR use a screwdriver and a hammer and tap the screwdriver a little then try to loosen them. It helps break them loose.
yeah them screws are a bitch at times...at the shop we use the impact driver with a hammer....it comes off with no time...u can also do the same with the screwdriver.....
but when i changed my cuz rotors i didnt have the impact driver..so i used the screw driver..and it accidentally stripped...so i had to chizzle it out..then hit the back of the rotor with a hammer till it came off
i didnt put them back on..just to make my life easier when i changed the brakes again...but u should put them back on..even though they are not needed
Modified by alloutmotor at 9:02 PM 2/28/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mOuse »</TD></TR><TR><TD CLASS="quote">Just drill out the screws, like the above is stated, the wheel keeps the rotor on, the screws are insurance, but i drilled them out back in feb 03 and i have yet to have any problem because there is no reason to really. It will just make ur life easier than impacting them out.</TD></TR></TABLE>
Dont drill the screws out. Get an impact driver from Sears, it cost like 26 dollars. The tool is not a waste of money for this one time you will use it again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh »</TD></TR><TR><TD CLASS="quote">they have them for $15 at my sears..</TD></TR></TABLE>
They need to bring your Sear's prices to my area
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toEknEEg »</TD></TR><TR><TD CLASS="quote">be careful with those two screws though. they are "fragile", i stripped one of them once. be careful and yes, they are hard to get out. take your time
Yes they do strip easy with them being a Philip's head screw. Ive changed out rotors and still stripped them with a impact driver, and then had to bust out the Dremmel and make the screw a flat head. I wish Honda would have made them that way from the beginning. If you do happen to strip the screws and need new ones or just want to change them out anyways. You cant get them at your local Auto store in the help section there like 2 bucks for 8 of them, the package is even marked Honda.
</TD></TR></TABLE>Yes they do strip easy with them being a Philip's head screw. Ive changed out rotors and still stripped them with a impact driver, and then had to bust out the Dremmel and make the screw a flat head. I wish Honda would have made them that way from the beginning. If you do happen to strip the screws and need new ones or just want to change them out anyways. You cant get them at your local Auto store in the help section there like 2 bucks for 8 of them, the package is even marked Honda.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cake-boy »</TD></TR><TR><TD CLASS="quote">
They need to bring your Sear's prices to my area</TD></TR></TABLE>
well thats not for a craftsman one. it doesnt matter though..
i dont want to sound harsh, but if you dont know how to take the rotor off of a car you shouldn't even attempt to do brakes. Just from the safety stand point alone.
i actually just changed my rotors and pads today. just take the caliper off with the 12 mm bolts. then take the two 17 mm bolts off that hold the caliper bracket on. next, use an impact screwdriver to take the two philips screws out. mine came out easy luckily. thats about it.
i got a cheap impact driver from harbor freight for $4. i had to wack the impact driver like a 100 times before it got lose. maybe i need to wack it harder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sting94112 »</TD></TR><TR><TD CLASS="quote">i got a cheap impact driver from harbor freight for $4. i had to wack the impact driver like a 100 times before it got lose. maybe i need to wack it harder. </TD></TR></TABLE>
people always say its good to have a hobby you enjoy
99electron_blue_si
12
Aug 3, 2005 08:18 AM
