90-93 teg shift linkage
Old Feb 28, 2004 | 08:14 AM
Exodus1811's Avatar
Default 90-93 teg shift linkage
wasup i got a integra 90 -93 shift linkage anybody kno the specs to how short i can cut it? so i can use it for my b-swap im welder so i can fit it and weld it good do i cut both shift linkage?
Old Feb 28, 2004 | 10:58 AM
BLT2FLY's Avatar
Default Re: 90-93 teg shift linkage (Exodus1811)
They both need to be cut, approx 2 1/4 inches shorter. Thats what mine were cut and they work great!
Old Feb 28, 2004 | 11:18 AM
91civicDXdude's Avatar
i cant find the picture, but what you can do is cut about 3" out of the middle, then you weld a nut on one cut part, then weld a threaded rod on the other part, that way you can adjust them...
Old Feb 28, 2004 | 11:23 AM
like so...
Old Feb 28, 2004 | 12:55 PM
Fobtions's Avatar
Default Re: (91civicDXdude)
just cut the stabilizer bar as llong as it needs to be exactly, theres no need for the bar to be adjustable.
Old Feb 28, 2004 | 02:58 PM
Exodus1811's Avatar
thanks yall good stuff
Old Feb 28, 2004 | 07:35 PM
if its adjustable, you dont have to worry about cutting it, welding it, and then come to find out its a little bit off and misplaces the shifter..
Old Feb 28, 2004 | 07:56 PM
Jays91DXhatch's Avatar
That's a good Idea. I'm modifying my stock D series linkages tomorrow. I might just go with the threaded Idea for the shift linkage, but I will just weld the stabalizer as that shouldn't need to be adjusted once it's in there and bolted.
I'll take pics and post them if that would help.
Old Feb 29, 2004 | 01:20 AM
Exodus1811's Avatar
Default Re: (Jays91DXhatch)
yea take pics
vtecc
Jun 1, 2015 10:53 PM
Cookiegsr
Apr 26, 2009 02:40 PM
hardware17
May 6, 2002 01:34 PM
E-lude78
Mar 1, 2002 06:16 PM
