How much weight can safely be removed from the stock ITR flywheel?
Old Feb 28, 2004 | 07:20 AM
WAFFLES's Avatar
Default How much weight can safely be removed from the stock ITR flywheel?
I'm soon to be pulling the tranny off of the motor to install a new final drive. I was planning on having a few pounds shaved off my R flywheel rather than buying a new flywheel. I have heard that you can only remove 5lbs off of a stock flywheel. Since the ITR flywheel is 3lbs lighter, does that mean that I can only have 2lbs safely removed, or is the R fw its own seperate casting? If I could take 5lbs off of the ITR fw that would be nice.
Any help or input is appreciated, and yes I did search first.
Old Feb 28, 2004 | 10:15 AM
Doctor CorteZ's Avatar
Default Re: How much weight can safely be removed from the stock ITR flywheel? (WAFFLES)
I took a few lbs off my old FW , it wasent worth it at all IMHO.
its not so much how much weight but more of where the weight is located , the upgrade to a nicely designed lighter FW was one of the better things I've done to the car.
that being said , I would go under 12lbs on a stock flywheel.
Old Feb 28, 2004 | 11:09 AM
JDMluvR's Avatar
Default Re: How much weight can safely be removed from the stock ITR flywheel? (Doctor CorteZ)
I thought it was never safe to take any weight off it.
Old Feb 28, 2004 | 11:56 AM
nightrider's Avatar
Default Re: How much weight can safely be removed from the stock ITR flywheel? (JDMluvR)
i honestly would not trust taking any weight off of any flywheel.
Old Feb 28, 2004 | 12:36 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">I'm soon to be pulling the tranny off of the motor to install a new final drive. I was planning on having a few pounds shaved off my R flywheel rather than buying a new flywheel. I have heard that you can only remove 5lbs off of a stock flywheel. Since the ITR flywheel is 3lbs lighter, does that mean that I can only have 2lbs safely removed, or is the R fw its own seperate casting? If I could take 5lbs off of the ITR fw that would be nice.
Any help or input is appreciated, and yes I did search first. </TD></TR></TABLE>
just purchase a light flywheel.. you'll probably end up getting a lighter flywheel anyway.
Old Feb 28, 2004 | 02:39 PM
Bbasso's Avatar
I would not bother unless your flat broke. I would just get a Comptech FW or what ever you like.
Old Feb 28, 2004 | 02:40 PM
QuanKwan's Avatar
exactly, best bet and safer to leave it alone or buy a new light flywheel
Old Feb 28, 2004 | 04:21 PM
SleepnCiViC's Avatar
yeh, and like someone mentioned its where the weight it located, performance flywheels are light and the weight it more centered. it requires less force to be reved up. thus holds less momentum then a factory fly wheel. which is why rpms drop much more quickly and allows your car to decelerate more quickly while down shifting.
Old Mar 1, 2004 | 09:22 AM
WAFFLES's Avatar
Default Re: (SleepnCiViC)
about how much does the comptech flywheel go for?
Old Mar 2, 2004 | 05:53 PM
Dirt's Avatar
Default Re: (WAFFLES)
When I had my '94 GS-R, I had King shave 5 lbs from my flywheel (18 lbs to 13 lbs). New ITR clutch, lighter fw, and new clutch MC. Felt killer. $100 to lighten a fw seems like a deal to me.
Old Mar 2, 2004 | 06:05 PM
Padawan's Avatar
Darth ModerVader
Default Re: (BrewCityR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrewCityR &raquo;</TD></TR><TR><TD CLASS="quote">When I had my '94 GS-R, I had King shave 5 lbs from my flywheel (18 lbs to 13 lbs). New ITR clutch, lighter fw, and new clutch MC. Felt killer. $100 to lighten a fw seems like a deal to me. </TD></TR></TABLE>
An extra $100 for an additional ~5-6 lb. reduction plus a replaceable friction surface seems like an even better deal.
Edit: Realized that my math was off.
Modified by Padawan at 8:45 AM 3/3/2004
Old Mar 2, 2004 | 06:08 PM
mikestypeR
Guest
Posts: n/a
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
An extra $100 for an additional ~7 lb. reduction plus a replaceable friction surface seems like an even better deal. </TD></TR></TABLE>
I second that
Old Mar 2, 2004 | 07:50 PM
redsivik's Avatar
Default Re: (mikestypeR)
how much does a stock ITR weigh?
Old Mar 3, 2004 | 12:22 AM
v t e c 2 3's Avatar
Default Re: (redsivik)
how much does the stock itr flywheel weigh??
Old Mar 3, 2004 | 02:54 AM
Dirt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">An extra $100 for an additional ~7 lb. reduction plus a replaceable friction surface seems like an even better deal. </TD></TR></TABLE>
Who makes a $200, 6 lb. flywheel? I just posted my story for the budget-minded out there. I'm sure you could safely shave 2-3 lbs. from a ITR flywheel, which is 15 lbs.
Old Mar 3, 2004 | 04:53 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrewCityR &raquo;</TD></TR><TR><TD CLASS="quote">Who makes a $200, 6 lb. flywheel? I just posted my story for the budget-minded out there. I'm sure you could safely shave 2-3 lbs. from a ITR flywheel, which is 15 lbs. </TD></TR></TABLE>
I realized this morning that I made an error in my quick math. Nevertheless, there are ~$200 7.5 lb. flywheels (which are what I was originally referring to), and they are an excellent deal, IMO. With the effort involved in removing and reinstalling the flywheel, I would personally prefer to spend the extra money for the lighter, longer-lasting piece, but others might not agree.
Old Mar 3, 2004 | 09:07 AM
WAFFLES's Avatar
Does anyone have an idea on how much you can find a comptech flywheel for?
Old Mar 3, 2004 | 09:41 AM
Toda is the daddy of all flywheels.
I see them used with a few miles for 2-250 all the time.
Old Mar 3, 2004 | 06:19 PM
WAFFLES's Avatar
Default Re: (Doctor CorteZ)
why do you say it's the daddy? Isn't the comptech the lightest?
Old Mar 4, 2004 | 07:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">why do you say it's the daddy? Isn't the comptech the lightest?</TD></TR></TABLE>
yep.
theres more than just weight to consider in rotating mass , its the location of the weight thats the key.
Old Mar 4, 2004 | 07:40 AM
sgT's Avatar
sgT
https://honda-tech.com/zerothread?id=766080
Old Mar 4, 2004 | 09:08 AM
WAFFLES's Avatar
Default Re: (sgT)
thanks steve!
Old Mar 4, 2004 | 11:38 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">yep.
theres more than just weight to consider in rotating mass , its the location of the weight thats the key.</TD></TR></TABLE>
This is inarguably true, however I have yet to see any objective data indicating that Toda's design has more favorable distribution of mass than other available flywheels (especially those that weigh less overall). I'd be interested in seeing such a comparison, but obtaining the data would likely prove difficult. Regardless, I remain a strong advocate of the CM/Fidanza pieces, which IMO are excellent in both performance and value.
EJ8_Man
Honda CR-V & Element
Dec 6, 2015 03:42 AM
Flood5
Honda Civic (2006 - 2015)
May 22, 2007 03:21 PM
fastitr01
Aug 23, 2004 03:01 PM
IN VTEC
May 7, 2002 04:15 AM
Spoold_R
Jan 1, 2002 07:54 AM
