LS/Vtec Question
Old Feb 28, 2004 | 12:35 AM
sir91's Avatar
Default LS/Vtec Question
What kind of compression am I looking at with the following set up?
LS Block
Type-R Crank
Type-R Rods
CTR pistons
B-16 Head milled 10ths
I am sure someone has already done this so your info would really help, thanks.
Old Feb 28, 2004 | 02:09 AM
Default Re: LS/Vtec Question (sir91)
damn hopefully you dont have valve-to-piston clearence issues..but Wow Hmmm i would say you would bet at 12.1 Comp Ratio.. mabey higher
Old Feb 28, 2004 | 03:13 PM
ArinX's Avatar
about 12.5 area
Old Feb 28, 2004 | 05:35 PM
Dancing is Forbidden's Avatar
Default Re: LS/Vtec Question (JayDieM)
j00 might wanna clay that engine....
Old Feb 28, 2004 | 10:14 PM
sir91's Avatar
Default Re: LS/Vtec Question (EF9_SiR)
What do you mean by clay that engine?
Old Feb 28, 2004 | 10:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sir91 &raquo;</TD></TR><TR><TD CLASS="quote">What do you mean by clay that engine?</TD></TR></TABLE>I mean you may want to check for valve clearances. There could be valve/piston clearance issues. Doing this will tell you if there is any problems. There could be, there might not be. You never know until you test it. On a more conventional engine this isn't so much of a problem, but with CTR pistons, milled head, ls block, vtec head, there COULD be issues.
Old Feb 29, 2004 | 10:42 AM
ArinX's Avatar
http://www.c-speedracing.com/h...y.php
Old Feb 29, 2004 | 11:01 AM
sir91's Avatar
Default Re: LS/Vtec Question (ArinX)
EF 9 and Arnix thanks for the explination of claying. Everyone else thanks for the input also.
Old Feb 29, 2004 | 11:06 AM
ArinX's Avatar
any time
Old Feb 29, 2004 | 11:11 AM
glad i could help. again, its not neccessary all the time when building, but I like to do it for ease of mind.
oneslodx
25
Apr 4, 2008 04:44 AM
gofastmobile
10
Sep 20, 2007 10:56 AM
cisurfer1
Feb 20, 2006 08:31 PM
DOHC VTEC EG
Jul 5, 2004 11:17 AM
racer4life
Feb 14, 2003 12:02 PM
