swap ? for 90 integ
ok i will be swapping my B16a (first gen 1 million series) into my new 90 integ however i would like to continue to use the a/c that came with the car will all of the a/c brackets swap over from old engine? also can anyone recommend so good mounts other than the inserts for this application
i know you can keep the a/c one of my friends has it http://bling.imperial.org/html/index2.html
i'll ask him what he had to do, you can email me at jzeien1@home.com and i'll tell you what i found out
later
later
you can keep air, use the a/c compressor and bracket that is on the B18A right now, it will all bolt to the B16 block. use the mounts that are in the integra as well. i dont like inserts either. use body fuser, thats what i use.
