main bearing problems???
Old Feb 27, 2004 | 10:17 PM
turbociv's Avatar
Default main bearing problems???
well, while inspecting my bearings earlier from last seasons engine, I noticed that on the main bearings they had some serious scratches on them. Also I noticed a bunch of metalic flake looking deposits stuck(melted) to the bearing. Now I cant tell if its dirt imbedded into the bearing material, or what could of caused the scratches. Is it possible that the machine shop let the tolerances be too loose causing metal flakes(breaking in process) to get in between the bearing and crank and melt or how could dirt (if thats what it is) be getting in there. I changed my oil reguraly and inspected it often. Also the downfall of the engine was when I spun rod number 4. Almost seems like oil starvation but how can I tell? Right now Im looking at a crappy haynes manuel about what my bearing symptoms might be but I am stuck between dirt imbedded into bearing material and overlay wipeout from oil starvation.
Sorry for the crappy pics, its the best I can do for now.
Modified by turbociv at 7:52 AM 2/28/2004
Modified by turbociv at 7:55 AM 2/28/2004
Modified by turbociv at 7:59 AM 2/28/2004
Modified by turbociv at 12:29 AM 3/9/2004
Modified by turbociv at 12:30 AM 3/9/2004
Old Feb 27, 2004 | 10:53 PM
turbociv's Avatar
thank you crappy imagestation.. Can someone host these for me??
Modified by turbociv at 8:03 AM 2/28/2004
Old Feb 28, 2004 | 09:41 PM
hayabusa160's Avatar
Default Re: main bearing problems??? (turbociv)
Old Feb 29, 2004 | 08:42 AM
turbociv's Avatar
^^^^^^^^^^^thank you ^^^^^^^^^^^
Old Feb 29, 2004 | 12:11 PM
MAX_CFM's Avatar
Default Re: (turbociv)
most of that is dirt
common problem in hondas the mains get trashed
Old Feb 29, 2004 | 02:48 PM
ArinX's Avatar
From Rockets forum, very informative
http://www.engineparts.com/pro...e.htm
Old Feb 29, 2004 | 05:37 PM
turbociv's Avatar
the specs near the lugs, look like copper deposits of some sort. Also on the backside of my rod bearings are kinda polished and swirly looking, so I am assuming that there is movement. What could cause movement in the rod bearings?? also did those main bearings really look that bad?
MAX_CFM, could some of that material on the bearings be from when I spun #4 rod bearings (eagle rods). But that still doesnt really explain why the specs look like copper. Should I be concerned with how that bearing looks?
ArinX, thanks for that bearing technology link for clevite. Very informative like you said.
Old Feb 29, 2004 | 07:22 PM
damntired42's Avatar
them bearings look identical to a set i put in with a new used crank shaft. i was told it was caused by the oil hole in crank, that crank was worn??? that i needed to get it turned. i checked with some micromitors and all seemd round ???
Old Feb 29, 2004 | 08:34 PM
turbociv's Avatar
before the install of my componants the crank was micro polished and the block was align honed so everything shoulda been perfect.
Old Mar 1, 2004 | 01:25 PM
Rocket's Avatar
Do you bearings look like this?
http://www.engineparts.com/pro...5.htm
Old Mar 1, 2004 | 05:37 PM
turbociv's Avatar
the mains do look like that in some spots (with brite rings around spots). Ill check the rod bearings tommorow when i can get them from my work..
Old Mar 8, 2004 | 03:46 PM
turbociv's Avatar
Default Re: (Rocket)
these are some pictures of my rod bearings. sorry for the quality but I am using my webcam.
why does the back side of my bearings look like they are cross hatched and polished? The eagle rods look the same way as the back of the bearings. what could cause these bearing failures????????
Old Mar 9, 2004 | 02:07 PM
turbociv's Avatar
bump
Old Mar 10, 2004 | 02:42 PM
turbociv's Avatar
any one else have any input?? I need to know whether or not the machine shop is responsible for this...
Old Mar 10, 2004 | 07:29 PM
SpoonyGSR's Avatar
I hate rap music
hahah you ****** and your little scratches in your bearings..
Old Mar 11, 2004 | 01:16 PM
turbociv's Avatar
yea, rod #4 looked hust like that but I didnt post the pick.lol
NoWorry's
May 6, 2013 06:12 PM
pkolaboy
Jan 9, 2008 08:50 PM
pentaq
Feb 15, 2005 09:59 PM
DjDrift
Oct 2, 2004 08:05 AM
jdmcivicferio
Mar 16, 2003 06:54 AM
