Grrrrrrrrr.... Code 14.
Old Feb 27, 2004 | 09:08 PM
Seraph0's Avatar
Default Grrrrrrrrr.... Code 14.
I've just finished rebuilding my engine. It's a 98 GS-R. I pulled out the motor, had it sleeved, installed forged pistons/rods and put everything back together. I still have the stock intake manifold, TB, cams, etc, etc. Very close to stock except for the internals (and the turbo setup of course.. ).
The very first time I fired it up it cranked and fired up perfectly with the stock OBD2 ECU. Idled flawlessly. Tried a OBD1 ECU with an adaptor harness. Fired up and idled.
Next day: Changed the injector clips on my harness for OBD1 injectors. Plugged in my resistor box and 880cc injectors. Made a chip for the 880s (Uberdata). Go to start car. Starts but immediately dies. Hrmmm.... Hold the gas open some... try it again... Car runs and stays running.
Try putting in stock size injectors (OBD0 I'm assuming since they are peak&hold and need the resistor box still). Crank the car. STILL won't idle on its own.... GRRRR... Getting a Code 14 for the IACV.
I have tried every which combination of ECUs, injectors, ROM burns, a different IACV, etc and no matter what I still have the same symptoms and the same code 14.
Now what changed from the first day I fired up until the 2nd that would make it decide to stop idling on its own. All I did was change the injector clips.
I temporarily fixed the problem by adjusting the throttle body stop, but I HATE the fact that I don't knoww hat happened. Any ideas?
Old Feb 27, 2004 | 11:44 PM
Mase's Avatar
Default Re: Grrrrrrrrr.... Code 14. (MarkC)
im gonna have to say its something hardware, wiring issue
Old Feb 29, 2004 | 09:59 AM
synergy004's Avatar
Default Re: Grrrrrrrrr.... Code 14. (Mase)
that facker mark fixed it, wiring issues troubled his black geo integra.
g
Old Feb 29, 2004 | 10:12 AM
Seraph0's Avatar
Default Re: Grrrrrrrrr.... Code 14. (synergy004)
Yup. Got it fixed. IACV wasn't getting power because I neglected to hook up every common wire when I did the resistor box install.
Important Note: EVERY one of those 4 wires you solder together to go to the resistor box are significant!!
DAtegLs
28
Nov 8, 2008 09:13 AM
pokemon
Sep 8, 2007 07:12 PM
92_VX_EG
Nov 15, 2006 02:14 PM
