How do you wire up the Injector Resistor box???
Old Feb 27, 2004 | 07:10 PM
markgo's Avatar
Default How do you wire up the Injector Resistor box???
I'm having a hard time following the instructions on forthgenhatch.com, the injector wires where really easy, but got a little confuse when it came to the resistor box, if anyone has a little more detail on the wiring please let me know thanks a lot for time
PS GRCCRX911 and Phatrick2332 thanks a lot for the site, it helped me alot
Thanks
Old Feb 28, 2004 | 08:39 AM
jlicrx's Avatar
Default Re: How do you wire up the Injector Resistor box??? (markgo)
you should have an injector resistor box with a gray connector on the side - you need the other side of this connector that goes to the engine harness with the wires cut - should be one yellow/black and four red/black - take the two yellow/black wires that went to the two DX injectors and connect them together and then connect them to the yellow/black on the connector to the injector resistor box - take the four red/black wires from the connector to the injector resistor box and connect one to each injector - doesn't matter what order - if you have injector resistor box without the engine side connector, you need to get this connector from a salvage yard - i see lots of resistor boxes on ebay without the other side of the connector with the wires on it - they are just about worthless, unless you want to hard wire it in with no way to disconnect in the future
Old Feb 28, 2004 | 02:04 PM
R6Boy69's Avatar
I've got one for sale if anyone needs one...
Old Feb 28, 2004 | 02:34 PM
USDM 4G VTEC's Avatar
Default Re: How do you wire up the Injector Resistor box??? (crXBoy69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crXBoy69 &raquo;</TD></TR><TR><TD CLASS="quote">I've got one for sale if anyone needs one...</TD></TR></TABLE>
me too lol
Old Feb 28, 2004 | 06:04 PM
Blaze45's Avatar
Brrraaaap!
Default Re: How do you wire up the Injector Resistor box??? (USDM 4G VTEC)
I found it easiet to run a wire form A15 for the injector resistor power cause there were like 3 different wires that were black and yellow on my harness, so thats what I did, then ran a wire to each injector.
Blaze
Old Feb 29, 2004 | 12:54 AM
markgo's Avatar
Default Re: How do you wire up the Injector Resistor box??? (jlicrx)
Hey thanks a lot, that made it a lot more simpler, have one more question for you, i have a HF CRX 88, and i was wondering would it be easier to just get a SI harness so i don't have to mess with the engine harness, the only wires i would need to wire up would be the ones to the ecu????
markgo
Old Nov 8, 2006 | 11:35 AM
92jdmhatch's Avatar
good info
Old Nov 8, 2006 | 11:39 AM
HonDelso's Avatar
takes more wiring to make an Si harness work in a HF chassis. you would have to change ALL the harnesses if you want to do less wiring. best to use your HF harness less work over-all to do.
MBlake55
Jul 18, 2008 10:06 AM
Dunc
Oct 2, 2005 02:12 PM
integramic
May 24, 2005 10:27 AM
TYPErCRX
Feb 28, 2005 03:27 AM
shivern
Nov 28, 2004 08:51 PM
