running Hondata, do i need a FPR?
Old Feb 27, 2004 | 04:54 PM
GT-KiLLa's Avatar
Default running Hondata, do i need a FPR?
im running hondata with my current setup, someone told me that i would need a FPR, is this true>? thought and comments please
thanks!
Old Feb 27, 2004 | 08:11 PM
GT-KiLLa's Avatar
Default Re: running Hondata, do i need a FPR? (GT-KiLLa)
anyone?
Old Feb 27, 2004 | 08:28 PM
Kataku2K3's Avatar
You don't need an aftermarket FPR just because you're running Hondata... Depending on your motor setup one may be useful but it is in no way required... Just may help out when tuning by triming or increasing your fuel press...
Old Feb 28, 2004 | 08:55 AM
boostn420's Avatar
Not necessary but you can increase injector flow with them, so when you getting it tuned, if you find that you are maxing out the injectors you can increase fuel pressure some and it should help at least a little.
Old Feb 28, 2004 | 02:44 PM
GT-KiLLa's Avatar
Default Re: running Hondata, do i need a FPR? (boostn420)
yeah i think my tuner maxed out the injectors (stock gsr injectors), and its still pinging a bit. i just recently bought rc310 injectors. would i still need a fpr?
Old Feb 29, 2004 | 10:17 PM
GT-KiLLa's Avatar
any help guys?
Old Feb 29, 2004 | 10:21 PM
Kataku2K3's Avatar
It really depends, since you're going to be running 310's and your Hondata has your injectors at 100% D.C. if you just put them in you'd be way too rich... It would probably be a good idea in your case just to buy an adjustable FPR, this gives you the capability to tune fuel pressure on the injectors and the injectors themselves... Still, in no way is it escential, it just makes little adjustments to your tuning easier... Good Luck
Old Mar 1, 2004 | 05:39 PM
GT-KiLLa's Avatar
Default Re: running Hondata, do i need a FPR? (Kataku2K3)
thanks !
Old Mar 1, 2004 | 05:43 PM
boostn420's Avatar
But then again, while its not necessary it will make him fail a visual for his smog. He might getaway with the other parts but an FPR will definetly make him fail and for no reason.
Old Mar 1, 2004 | 06:47 PM
Kataku2K3's Avatar
Good point, I didn't know that as we don't have to deal with SMOG in Oregon
Old Mar 1, 2004 | 07:01 PM
boostn420's Avatar
lucky bastards!
Old Mar 2, 2004 | 09:29 PM
GT-KiLLa's Avatar
yeah , smog laws suck here in cali. thats why i got a hook up at the DMV
Old Mar 2, 2004 | 09:53 PM
GSR GRN97's Avatar
no don't think so but i put one on and got mad power gains for the $$$$ Try a B&M command flow w/ the gauge. It was a little over 100.00 and well worth it. You will be able to match your hondata w/ air/fuel curve much better and besides for that you spent some $$ on the hondata whats a little more gonna hurt?
550whpcivic
Engine Management and Tuning
Oct 25, 2010 10:54 PM
CaptainMorgan
Dec 25, 2003 09:51 PM
Diego Boost
Feb 26, 2003 11:10 AM
Rob Dizzle
Oct 19, 2002 09:59 AM
BlackGSR
Jul 24, 2002 01:01 PM
