v-afc
Old Feb 27, 2004 | 04:15 PM
trackstar00's Avatar
Default v-afc
i bought a vafc vtec controller and properly installed it i have a aem cold air intake on a 2.3l sohc vtec was wondering if anyone new the tuning i would need to input to the unit to start out
Old Feb 27, 2004 | 04:26 PM
Crono139's Avatar
Default Re: v-afc (trackstar00)
Dyno tune it for best results.
Old Feb 27, 2004 | 05:13 PM
fw190bvi's Avatar
Default Re: v-afc (Crono139)
greddy claims the Vafc cant tune vtec engagement points, as the SOHC vtecs have variable engagement points.......so why do SOHC accorders waste extra money on a feature they cant use aka. not buying a Safc
Old Feb 28, 2004 | 10:23 AM
twkdCD595's Avatar
Default Re: v-afc (fw190bvi)
I agree about dyno'ing.
fortunately it works on the f22b1 and its sohc vtec.
however the newer f23 models I heard it does not work properly, but cannot confirm.
Old Feb 28, 2004 | 07:42 PM
Crono139's Avatar
Default Re: v-afc (twkdCD595)
It works fine with the F23.
A'PEXi made a mistake in their pinouts for the F23. That's the only reason there has been any doubt about it.
Old Feb 28, 2004 | 07:45 PM
fw190bvi's Avatar
really??.....so then does the VAFC override the ablility for variable vtec engagement points??.....therefore making the f22 engage like an H22 (at set points as the engine revs)
Old Feb 28, 2004 | 08:45 PM
97F22B2's Avatar
i remember when neidejb was using the VAFC on his setup he had to the VAFC set to 3100k and it enagged there everytime no matter what the load. So i would assume it doesn override the ECUs load controls(all speculation though)
Old Feb 28, 2004 | 08:57 PM
Crono139's Avatar
Default Re: v-afc (97F22B2)
Yeah, I don't see why it shouldn't work.
It's just telling the ECU to engage V-TEC at that RPM from now on.
Old Feb 28, 2004 | 09:16 PM
Legendaryyaj's Avatar
So has Apexi posted the corrected Pins for the F23 or will u guys make me search for it one here? Anyone got it cuz im planning on buying one in the real near future.
Old Feb 28, 2004 | 09:37 PM
twkdCD595's Avatar
Default Re: v-afc
with how the vafc is wired in, the ecu can not bypass the apexi unit... so I am confused how the ecu would be able to override your controller. you cut the vtec signal wire and it then runs through the controller.
anyways good to know on the f23... I thought they were different than the f22b1 I have.
Old Feb 29, 2004 | 02:57 PM
Crono139's Avatar
Default Re: v-afc (Legendaryyaj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legendaryyaj &raquo;</TD></TR><TR><TD CLASS="quote">So has Apexi posted the corrected Pins for the F23 or will u guys make me search for it one here? Anyone got it cuz im planning on buying one in the real near future.</TD></TR></TABLE>
I have the correct pinouts saved somewhere on my computer. I can't even remember who posted them. It was either from Toronto Accords, Honduh, or even HondaSociety.
I'll post the pinouts as soon as I find them.
Traser
Nov 17, 2006 11:30 AM
ldanphanl
Mar 10, 2005 09:38 PM
JDMlyfestyle
Jul 19, 2004 09:27 AM
JDMACCORD
Feb 1, 2002 12:32 PM
