radiator support removal?
Old Feb 27, 2004 | 04:09 PM
TK715's Avatar
Default radiator support removal?
im trying to remove my radiator support off my 98 civic...is it really complicated or easy? advice please
Old Feb 27, 2004 | 04:25 PM
Benbuilt4u's Avatar
Default Re: radiator support removal? (TK715)
it has to be drilled off or cut. good luck
Old Feb 27, 2004 | 04:29 PM
TK715's Avatar
Default Re: radiator support removal? (Benbuilt4u)
so is it possible to replace with a new one?
Old Feb 27, 2004 | 04:37 PM
sting94112's Avatar
you would have to weld a new one back on
Old Feb 27, 2004 | 04:42 PM
TK715's Avatar
Default Re: radiator support removal? (sting94112)
how much do body shops charge do u know?
Old Feb 27, 2004 | 05:42 PM
x2gold's Avatar
not that bad, but you better have some knowledge and patience when lining things up. there are certain tools that make this easier, such as a spot weld drill bit, or tool, there are a few varities that can be found at paint stores (colors, auto paint world, house of colors etc). anways, it can be removed. As for a shop doing it, they would charge what the labor book suggests which would be alot. But, if u take off all the parts and have them remove the radiator support, it will be cheaper for you.
Good luck
Old Feb 28, 2004 | 12:19 PM
slixxracing's Avatar
Default Re: radiator support removal? (x2gold)
Doing the job isnt all that hard. Just break off all the OEM welds w/ a drill bit. Once you have all the welds broken off, the radiator support should fall right off. With the new radiator support in it's place, grab like 3-4 vise grips and find places where you could clamp the radiator support to the chassis of the car. BUT MAKE SURE EVERYTHING IS LINED UP BEFORE YOU START WELDING. Once everything looks ok and lined up perfect...start your welding. I was lazy and asked my neighbor how much he will charge me to do the job and he quoted 300 bucks, w/ parts and labor. I was like damn....never mind ill do it myself.
mattyfo0z
Aug 11, 2010 09:35 AM
Boostn B20
Aug 21, 2008 02:27 PM
cilvia
20
Apr 18, 2007 07:34 AM
B18CYAAA
Jul 14, 2003 03:22 PM
integra0260
Jul 26, 2001 02:22 PM
