5th Gen Koni Yellow, adjustment for rear, got a PROBLEM??
Old Feb 27, 2004 | 03:15 PM
DB8's Avatar
DB8
Default 5th Gen Koni Yellow, adjustment for rear, got a PROBLEM?? "Link Added"
here's a link from Koni..........
http://www.koni-na.com/adjustment.html
the one i am looking at is the second one from the top, i am really confuse, don't really understand what i have to do to adjust it even after i read it, anyone got any indepth info on this??
or pictures of what they are talking about?
Modified by DB8 at 3:44 PM 3/3/2004
Old Feb 27, 2004 | 03:38 PM
Spider Man's Avatar
Default Re: 5th Gen Koni Yellow, adjustment for rear, got a PROBLEM?? (DB8)
Did you try pulling the side panel in the trunk to access the shocks?
Old Feb 27, 2004 | 04:17 PM
DB8's Avatar
DB8
Default Re: 5th Gen Koni Yellow, adjustment for rear, got a PROBLEM?? (Spider Man)
yeah, i pull the panels off, but still couldn't get the **** in place to adjust it, but once i look into the shock tower, i wonder if i am suppose to use the white ****(koni provided) to adjust it? or use some other tools? i can't seem to see the adjust thing for the **** to go into it, seems like i can only use a alley key or something to adjust it..........anyway, if anyone got any details in this, please post
Thanks
Old Feb 27, 2004 | 04:47 PM
Luisito825's Avatar
the only i know how is to take it out of there and adjust them and put them back in.
Old Feb 27, 2004 | 05:32 PM
Spider Man's Avatar
Default Re: 5th Gen Koni Yellow, adjustment for rear, got a PROBLEM?? (buss)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buss &raquo;</TD></TR><TR><TD CLASS="quote">the only i know how is to take it out of there and adjust them and put them back in. </TD></TR></TABLE>
You guys are making me glad I got KYB.
All I have to do to adjust rears on that car is simply reach down behind the wheel and turn the ****.
Old Feb 27, 2004 | 08:04 PM
fliplyricist1's Avatar
I heard yellow owners had to shave a small portion of the body metal in order to access that area easier : /
might want to just take a little bit off with a dremel and a little bit of sanding to make it look professional
Old Mar 3, 2004 | 02:44 PM
DB8's Avatar
DB8
Default Re: 5th Gen Koni Yellow, adjustment for rear, got a PROBLEM?? (fliplyricist)
link added, help me out and explain it to me guys...........
thanks in advance
Old Mar 3, 2004 | 04:20 PM
urbanlegend21's Avatar
New User
that link does nothing for you
those are for damper adjustable shocks
you have rebound adjustable shocks
to adjust them use a pair of pliers and count the rotation of teh small **** on top or flip your rear seat forward, remove the 2 panels from in front of the shock towers and adjust to where you want them and put the panels back
there is frankly no real easy way to adjust the rears
Old Mar 11, 2004 | 05:03 PM
fishnfst's Avatar
Default Re: 5th Gen Koni Yellow, adjustment for rear, got a PROBLEM?? "Link Added" (DB8)
That is the adjustment instructions for the koni reds not the yellows. The reds you have to remove the shock from the car to adjust them. The yellows there is a **** that fits onto a rectangular or squarish nipple on the top. Are you sure you have the yellows? The yellows are by far the easiest shocks to adjust.
Old Mar 11, 2004 | 10:36 PM
accordfreak's Avatar
Default Re: 5th Gen Koni Yellow, adjustment for rear, got a PROBLEM?? "Link Added" (fishnfst)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst &raquo;</TD></TR><TR><TD CLASS="quote">That is the adjustment instructions for the koni reds not the yellows. The reds you have to remove the shock from the car to adjust them. The yellows there is a **** that fits onto a rectangular or squarish nipple on the top. Are you sure you have the yellows? The yellows are by far the easiest shocks to adjust.</TD></TR></TABLE>
the rectangluar nipple is only for the front yellows with use of the white ****. the rears you have to adjust it some other way. It does not have the retangular nipple like the front ones. I have had the koni yellows front and rear for about 4-5 years and haven't had the time to figure out how to adjust them..
BUMP for info..
Old Mar 11, 2004 | 11:13 PM
im_the_teacher's Avatar
i have koni yellow on my car, is really easy to adjust front or rear....on the rear you want easy access(if u adjust often) remove the back plate...unscrew 4 14mm nuts...
Old Mar 12, 2004 | 03:53 AM
dcaccord's Avatar
Default Re: 5th Gen Koni Yellow, adjustment for rear, got a PROBLEM?? "Link Added" (im_the_teacher)
I have Tein SS on my coupe, and they adjust the same way as Konis. You have to be a contortionist to get your hand and a tool in there to adjust the rear.
97BB6Type-SH
May 30, 2008 11:32 PM
racingant
Nov 12, 2004 06:59 PM
Undercover_Skank
Feb 21, 2004 05:57 PM
AccordVtec
Mar 7, 2003 05:30 PM
EleanoR
Oct 21, 2002 07:28 PM
