Engine weak when warmed up?
Old Feb 27, 2004 | 08:39 AM
JDM-Vic's Avatar
Default Engine weak when warmed up?
When I get in my car in the morning and start it up, I let it warm up for about 5mins. Then I start driving and its quick, but after about 15mins of driving, it will bogg like mad. When I start driving from a dead stop and pin it so its at WOT it will go slower than a old lady driving her 1980 Chrysler Dynasty. And I aint exaderating that at all. But before its completly warmed up its as quick as can be. Anyone know whats up? I have replaced my sparkplugs, fuel filter, plug wires and im out of ideas. Theres no CEL.
Old Feb 27, 2004 | 09:52 AM
JDM-Vic's Avatar
Old Feb 27, 2004 | 10:52 AM
JDM-Vic's Avatar
bump
Old Feb 27, 2004 | 12:07 PM
McDade's Avatar
Default Re: Engine weak when warmed up? (JDM-Vic)
compression test
leak down test
go from there
Old Feb 27, 2004 | 01:17 PM
civboy115's Avatar
Default Re: Engine weak when warmed up? (McDade)
chcek your rear o2 sensor. When mine had a short in it, my car drove great until it warmed up a bit and the cat got hot. Then it bogged like mad. Have it checked and replace if neccasary. That is also a good indication of fuel filter, but u already replaced that....
good luck tho
Old Feb 27, 2004 | 01:45 PM
JDM-Vic's Avatar
Another thing is that sometimes it will have an idle problem.
I have tried disconecting the O2 sensor, still bogs once warm, and the Knock Sensor. And nothing seems to help.
Old Feb 27, 2004 | 08:43 PM
Shadow Templar's Avatar
Default Re: (JDM-Vic)
Have you ever heard of heat soak? I doubt that would be the issue but i figured itd be worth it to mention. Heat soak is when the engine compartment heats up in such a manner that your intake is sucking in hot air, which your car does not like to breathe in, and could bog abit. just my .002
Old Feb 29, 2004 | 10:42 AM
JDM-Vic's Avatar
Old Feb 29, 2004 | 08:08 PM
JDM-Vic's Avatar
bump
Honda2001-85
Honda Civic (2001 - 2005)
Jul 27, 2015 09:39 AM
Montx
Apr 28, 2009 05:47 PM
89canefighter
Mar 15, 2009 02:51 PM
wanderinglost
Nov 7, 2008 08:31 AM
yorktonite
May 23, 2003 09:01 PM
