93 accord ecu codes
Old Feb 27, 2004 | 07:53 AM
fsarfino's Avatar
Default 93 accord ecu codes
Hey guys easy question
how do you read the code on this car? Is there a connector that you need to jump out? if so where is the connector located at and what does it look like ?
Thanks guys !
Old Feb 27, 2004 | 10:58 AM
.bagged's Avatar
Default Re: 93 accord ecu codes (fsarfino)
Here ya go mang..
http://hybrid2.honda-perf.org/tech/codes.html
Old Feb 27, 2004 | 10:52 PM
fsarfino's Avatar
ok cool thanks for the above info
I dont own this car my brother does. Since I have never owned a accord, only civic/crx/integra's does this ecu read the same way as say a 88-91 civic or do you need to jump out a connector.
Thanks
Frank
Old Feb 28, 2004 | 06:38 AM
The_Todd's Avatar
Farts in the shower
I have never had to "jump" my ecu to get codes. For 4th gens usually you just wait till you get the code then look at the ecu and it should flash a long set for the first number and a short flash for the second number ie 2 long flashes + 3 short flashes=code 23. GL
Old Feb 28, 2004 | 08:04 AM
Chiovnidca's Avatar
Default Re: 93 accord ecu codes (VRDrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">I have never had to "jump" my ecu to get codes. For 4th gens usually you just wait till you get the code then look at the ecu and it should flash a long set for the first number and a short flash for the second number ie 2 long flashes + 3 short flashes=code 23. GL</TD></TR></TABLE>
That only applies to 1990 models and older. 1991 thru 1993 models you have to jump the service check connector behind the right kick panel.
96_Wagon
Oct 6, 2015 07:38 AM
honda4674
Apr 5, 2006 08:05 PM
dblack
May 4, 2004 01:35 PM
tpr
Mar 18, 2003 09:26 AM
td04civic
Oct 2, 2002 08:11 PM
