ITR muffler spec..... [SEARCHED]
Old Feb 27, 2004 | 07:25 AM
joneblaze's Avatar
Default ITR muffler spec..... [SEARCHED]
Hey all,
i just bought an ITR muffler for my planned exhaust setup for my 95 LS. I was going to fit it to some custom 2.25" catback piping for a light mod. Over the research i've done on the topic of using an ITR muffler on other dc2's, it states the ITR muffler has a 2.25" inlet, which ties into the ITR catback piping size as well. Problem is, the ITR muffler i've just bought measures a 2" inlet (this is measured right at the inlet hole, where the bpipe and other piping has been chopped. I only purchased the muffler itself.)
Now people might suggest I've bought a bogus muffler, but I got it from an acquaintance, and also, it looks EXACTLY like the muffler in this post--->
[URL]https://honda-tech.com/zerothread?id=779124[\URL]
If anyone could shed some light on this it'd be greatly appreciated. A friend suggested that the '96 ITR muffler could have had a different sizing, or that the muffler is in fact a 2" inlet, tapering from the 2.25" system?
At the end of the day, if i fit this to my original plan of 2.25" catback, it'll be a waste of time correct? As in the 2" inlet muffler will merely "choke" or bottleneck my little modified exhaust system?
thanks in advance guys,
Jon
Old Feb 27, 2004 | 07:37 AM
type-r 01 886's Avatar
Default Re: ITR muffler spec..... [SEARCHED] (joneblaze)
see link in sig, check the specs section.
Old Feb 27, 2004 | 07:56 AM
joneblaze's Avatar
Default Re: ITR muffler spec..... [SEARCHED] (type-r 01 886)
Dude i just checked out your "specs" section.
http://www.typeracing.com/specs.html
There's nothing there that helps me.
Old Feb 27, 2004 | 09:22 PM
96dc2's Avatar
I have this saved in my notepad, but it's regarding the exhaust. It was posted my SMSP.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">
Stock ITR is 57mm OD (2-1/4") with multiple bottle necks. The worse being at the B pipe inlet which is 1-3/4" ID. The B pipe necks down to around 2" or 2-1/16" OD at the B pipe to Axle back joint and the muffler tubing is 54mm OD and then necks again to 52-53mm right before it enters the muffler.
Old Feb 27, 2004 | 09:34 PM
joneblaze's Avatar
Awesome, thanks for that. I suppose I'll sell it and find something with a 2.25" inlet.
cheers for your help.
Old Feb 27, 2004 | 09:46 PM
B18C5's Avatar
Default Re: (joneblaze)
Why not just remove the bottleneck and weld on a larger pipe? I did it with the inlet to my B pipe with a pipe from SMSP.
Old Feb 27, 2004 | 10:28 PM
nightrider's Avatar
why not go 2.5"?
Old Feb 27, 2004 | 10:30 PM
96dc2's Avatar
Default Re: (nightrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightrider &raquo;</TD></TR><TR><TD CLASS="quote">why not go 2.5"?</TD></TR></TABLE>
He has an LS.
mynameizstitch
15
Jul 12, 2009 12:53 PM
MansuDC2
Mar 8, 2006 10:20 PM
threatcon13
Nov 15, 2001 06:11 PM
