lsvtec main / oil seals
since you're using the itr pump, get an itr oil seal. as for the rear main seal, it should be coming from your factory ls block correct?then get one for the ls. but you never know, they may be the same part #.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aemcivic_02917 »</TD></TR><TR><TD CLASS="quote">what o ring?
the o-ring is on the oil pump
Ls_V_TurboSi
May 10, 2006 05:14 AM
