Home made oil catch can (with pics).
Old Oct 14, 2001 | 12:26 PM
Tommy_Gunns's Avatar
Default Home made oil catch can (with pics).
Thought I'd share with everyone my home made oil catch can.
1. Take a perfectly good SS mug (coffee cup I found at a local store).
2. Silver solder (causes welding would have punch a hole through it) SS fitting onto it. Putting a baffle in it would be a good idea. I sand blasted it to make it pretty.
3. Find a thin sheet of SS plate and solder it to the opening of the cup. You'll also need to get some clear tubing for the sight glass.
4. Solder on a mounting bar and install the clear tubing. Viola...the finished product.
All I have to do now is mount it somewhere in my engine bay...which will involve making 2 holes onto the mounting bar and trimming the excess bar off (the mounting bar was made extra long cause I have not decided where to moung it yet...likely on the rad support).
Comments?
Old Oct 14, 2001 | 12:29 PM
Scorpaznatica's Avatar
New User
Default Re: Home made oil catch can (with pics). (Tommy_Gunns)
Simple, and effective. Nice
Old Oct 14, 2001 | 12:43 PM
MrBite's Avatar
to homemade schtuff Looks sweet!
Old Oct 14, 2001 | 12:45 PM
EPGONZALEZ's Avatar
Default Re: Home made oil catch can (MrBite)
VERY COOL!!! I would like to try something like that..have a TIG..make the welding a little easier..where did you get the fittings?
Old Oct 14, 2001 | 12:53 PM
Default Re: Home made oil catch can (EPGONZALEZ)
The fitting are SWAGELOK...SS tubing and SS farrows. I got them from work
TIG might of worked as well. The mug was double walled with very thin walls.
Old Oct 14, 2001 | 01:09 PM
D's Avatar
D
looks good except:
might have been easier to use the cup right side up, instead of upside down.... bracket could have been built into the lid then. doesn't matter tho, unless it leaks..
also, i'm not sure what you're baffle is for... for an oil/water/vapor separator, the baffles should be horizontal (with holes in them) so the hot vapors have something to condense on (like a distillation or liquid/liquid extraction column). maybe it doesn't make much difference...
how'd you 'weld' this chit? "silver solder".. and a soldering iron????
D
Old Oct 14, 2001 | 01:31 PM
Default Re: Home made oil catch can (D)
Well, I kinda thought of stuff as I went along. I didn't come up with a way to mount it till I was finished, probably would have been better to have it right side up.
The baffle is to separate the inlet and outlet nipples...otherwise it would have been an almost direct path...it is just there to ensure that no oil blows directly out of the can. I made the baffle that way cause it made installing it alot easier than if it were flat.
Silver solder and a propane torch. Silver solder is strong chit.
looks good except:
D
[Modified by Tommy_Gunns, 4:32 PM 10/14/2001]
Old Oct 14, 2001 | 01:56 PM
D's Avatar
D
Default Re: Home made oil catch can (Tommy_Gunns)
Werd. Grass roots style....
D
Old Oct 14, 2001 | 02:40 PM
Mr. Thunderlips's Avatar
pretty cool i guess...looks kinda ghetto...function over form for some i guess...why not just spend a couple bucks for a real one...maybe you got alot of time on your hands?
Old Oct 14, 2001 | 03:10 PM
integRated109's Avatar
Default Re: Home made oil catch can (Slo_Teg)
i have friends with complete home-made turbo kits. theres just something cool about having functional stuff in your car that you made. looks good man.
Old Oct 14, 2001 | 03:15 PM
OneThirtyEight's Avatar
Default Re: Home made oil catch can (integRated109)
pardon me being dumb. What is an oil catch can?
Old Oct 14, 2001 | 03:32 PM
TODAwhore's Avatar
Default Re: Home made oil catch can (97blackteg)
Cool & good job...about how much in supplies did it cost you?
93dx--hatch
May 2, 2004 08:07 AM
T25 civic
Oct 15, 2002 12:52 PM
thaiphob
13
Sep 11, 2002 01:34 PM
Tommy_Gunns
Aug 13, 2002 03:40 PM
jdmciviceg
Mar 21, 2002 11:01 AM
