What does the EGR valve actually do?
Old Feb 26, 2004 | 04:15 PM
. o 69 o .'s Avatar
Default What does the EGR valve actually do?
I took mine off today so i could pull my manifold to change a leaky gasket. Just curious what its for. It was all covered in carbon build-up so it got me wondering what the heck it does.
Old Feb 26, 2004 | 06:15 PM
Kataku2K3's Avatar
Default Re: What does the EGR valve actually do? (B16B)
It's really just used for emissions and stands for exhaust gas reciculation... When the vavle is open exhaust gases are allowed to be recirculated back into the IN manifold where they are reburned... Carbon buildup is completely normal as you can imagine... Hope this helps, Peace
EDIT: Thanks SoCalAutotech, didn't even realize I put that... corrected
Modified by Kataku2K3 at 8:09 PM 2/26/2004
Old Feb 26, 2004 | 06:17 PM
. o 69 o .'s Avatar
Default Re: What does the EGR valve actually do? (Kataku2K3)
if i was to eliminate it, would it serve any performance improvement?
Old Feb 26, 2004 | 06:22 PM
Kataku2K3's Avatar
Maybe a little as you won't be reintroducing exhaust gases back into your intake but I don't really know for sure as I've never tried it on the dyno (my guess would be very little if any tho)... On some H22 swaps in the past we've made a block off plate so that you don't have to wire in the EGR and it ran no different...
Old Feb 26, 2004 | 06:44 PM
. o 69 o .'s Avatar
awsome... thanks for the info
Old Feb 26, 2004 | 06:57 PM
Billy Blaze's Avatar
EGR actually stands for Exaust Gas Recirculation. It doesn't always stay open. Depending on the engine temp and rpm's it will open and close at different rates. The EGR's purpose is to help remove NoX from your exaust. If you decide to remove the EGR valve I doubt you will have any increase in horse power. If your cat. converter is still on the vehilce its going to cause it to work harder.
H22_CB7_JAY
May 1, 2012 12:29 PM
'90crxSI
Sep 14, 2008 05:38 PM
Jakester9500
Jan 9, 2007 12:34 PM
spnbb2
Sep 3, 2004 05:30 AM
Redline130
Feb 23, 2002 05:21 PM
