Recovering door panel armrests?
Old Feb 26, 2004 | 03:07 PM
cvclover's Avatar
Default Recovering door panel armrests?
How do I put red fabric on the door panel armrests like CTR door panels?
What is the material?
I have a 99 Si
Old Feb 26, 2004 | 03:14 PM
^jefs0ng's Avatar
Banned
I'd like to know what specific material this is too. I was consdering doing my door panels in hello kitty fleece but I want suedeish material instead .
Old Feb 26, 2004 | 04:34 PM
2000SIsparky's Avatar
Default Re: Recovering door panel armrests? (cvclover)
The material I used is called Pique Solid. I got it from Joanns Fabrics. It runs about 5 dollars a yrd.
old
new
Here is the "how-to":
First you need to get the insert out of the door. There are 16 plastic rivets on there. What I did was shaved the top off the rivets and pushed the insert through.
Second take off the old carpet. Clean up the plastic. Make sure the plastic is clean of all the carpet for the adhesive to take its full effect.
Third what I did was take a 1/4" tap and taped for the screws that I was going to use. (see photo)
Fourth I sprayed the adhesive on it. Any spray will do. Then apply the material of choice. Try to lay the material as flat as possible. Can be a pain to get all the wrinkles out.
Fifth Use 1/4" x 1/2" screws with washer to secure the inserts back to the door panel. Be sure not to go through the other side.
Re-install door panel and your done.
I think that is about it. any questions let me know.
Old Feb 27, 2004 | 12:22 PM
cvclover's Avatar
Default Re: Recovering door panel armrests? (2000SIsparky)
So that red material is called pique solid too?
Looks awesome
Old Feb 27, 2004 | 12:58 PM
JDM CTR EK's Avatar
Nice write up!
Old Feb 27, 2004 | 02:46 PM
KiLLa CaM 06's Avatar
Default Re: (JDM CTR EK)
some red tweed is also nice to use.
Old Feb 27, 2004 | 03:04 PM
BolivianDc2's Avatar
Default Re: (KiLLa CaM 06)
does anybody know a material that have the same texture and color as Sparco's Competition Fabrics?
Old Feb 27, 2004 | 04:23 PM
cvclover's Avatar
How much is tweed, and is it sold at Jo-Ann?
Old Feb 27, 2004 | 04:32 PM
.ShawnD.'s Avatar
Default Re: (BolivianDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianDc2 &raquo;</TD></TR><TR><TD CLASS="quote">does anybody know a material that have the same texture and color as Sparco's Competition Fabrics?</TD></TR></TABLE>
alcantara? aka fo suede
Old Feb 27, 2004 | 04:36 PM
OC 335i's Avatar
Sparco sells material.
I still have red material left from red Sparco Torinos.
Old Feb 27, 2004 | 04:47 PM
Default Re: (JMS JT)
yea, but the competition material sells for over $100. I'm looking for a cheaper alternative
They sell the competition material, jacquard, and alcantara.
competition is the cheapest
Old Mar 3, 2004 | 08:58 AM
cvclover's Avatar
Bump
Is it absolutely necessary to drill a 1/4'' hole? Whats it for?
Old Mar 3, 2004 | 07:50 PM
Default Re: (cvclover)
you have to hold the insert in the panel. otherwise what would you do.
91efbluehatch
Jul 21, 2010 06:53 PM
suhteevin
Jan 6, 2009 09:04 PM
cys19
Paint and Body
Feb 15, 2008 07:46 PM
93hybrid
Dec 5, 2002 11:41 AM
