I need some help with this. . . .
Old Feb 26, 2004 | 02:55 PM
EG6-DC2's Avatar
Default I need some help with this. . . .
I have a little problem with getting my crx to idle, whoever had it before me had put a d16y7 in it, i dont know why anyone would waste their time with it, but it is the dx motor out of a 96-00 i believe. the ecu that i am running is a pm6. it idles at 2500 constant, surging of plus or minus 100. i am getting the codes 5 and 7, which is the tps code, and map sensor code if im correct. i have replaced both, after replacing the map sensor, the only code that it was throwing was a tps code, replaced that and now i am getting both codes again. i have replaced the tps 3 times with different ones each time, nothing changes. i have sprayed carb cleaner all around the intake so im pretty sure i dont have any leaks in the intake manifold. the intake is not on right now but i dont think that would have anything to do with it. when it is running it seems like it is running rough like the timing is off or something. i really have no idea. if anyone could help me out i would greatly appreciate it. thanks
Old Feb 26, 2004 | 04:26 PM
scdarksol's Avatar
Default Re: I need some help with this. . . . (EG6-DC2)
hmm try adjusting your throttle cable? If not, you might have an airpocket in your cooling system. Or worst case you have a bent valve.
Hanmin
11
Sep 30, 2010 10:35 AM
d_boi_swag
Jul 5, 2009 12:14 PM
iandian
Oct 10, 2007 01:06 PM
Achenar
Oct 2, 2004 01:45 PM
91 POS
Oct 10, 2003 03:17 PM
