Where can I get one of these for an ef with a bseries?
Old Feb 26, 2004 | 12:48 PM
BseriesHatch's Avatar
Default Where can I get one of these for an ef with a bseries?
I want one of these engine dampers to help with engine rocking. But I can't find one that will fit an ef! Does anyone know where to get one?
Old Feb 26, 2004 | 12:55 PM
customx_'s Avatar
New User
Default Re: Where can I get one of these for an ef with a bseries? (BseriesHatch)
i think eggman sells them for ef
Old Feb 26, 2004 | 01:00 PM
Patch's Avatar
Default Re: Where can I get one of these for an ef with a bseries? (RIDE or die)
Whats the point? If you have any aftermarket mount kit (Hasport, HCP, etc) your engine does not move at all. If you don't have aftermarket mounts like I listed above, then a stupid shock bolted to your firewall isn't going to do crap compared to poly engine mounts.
Old Feb 26, 2004 | 01:05 PM
customx_'s Avatar
New User
Default Re: Where can I get one of these for an ef with a bseries? (Patch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patch &raquo;</TD></TR><TR><TD CLASS="quote">Whats the point? If you have any aftermarket mount kit (Hasport, HCP, etc) your engine does not move at all. If you don't have aftermarket mounts like I listed above, then a stupid shock bolted to your firewall isn't going to do crap compared to poly engine mounts.</TD></TR></TABLE>
couldnt of explained it any better
Old Feb 27, 2004 | 05:53 AM
I actually already have the az race and machine mounts that are very stiff but my motor still moves just a little. I drag race a lot so I am kind of looking for almost no motor movement.
Old Feb 27, 2004 | 06:21 AM
wickedEFguy's Avatar
instead of using poly mounts your should have made some custom solid metal mounts, you would have pretty much zero engine movement
Old Feb 27, 2004 | 06:32 AM
1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIDE or die &raquo;</TD></TR><TR><TD CLASS="quote">
couldnt of explained it any better</TD></TR></TABLE>
It's couldn't have
Old Feb 27, 2004 | 06:34 AM
Default Re: (wicked B16)
I daily drive my car so I really didn't want to "weld" my motor in. The damper is adjustable anyways so I can adjust the stiffness whenever I want to. Stiff for when I race and loose for when I daily drive. Anyone know where to get one?
Old Feb 27, 2004 | 06:55 AM
joesefcivic's Avatar
make one!
Old Feb 27, 2004 | 01:25 PM
Default Re: (joesefcivic)
Anyone else?
89hatcher
Nov 4, 2007 05:19 AM
HxCforever
Oct 26, 2007 10:35 AM
mymeatb18"
Apr 24, 2006 12:16 PM
mymeatb18"
Apr 21, 2006 05:39 PM
C-speed
Apr 20, 2005 01:25 AM
