Oil in distributer.
Old Feb 26, 2004 | 08:41 AM
-Bionic-'s Avatar
Former Sponsor
Default Oil in distributer.
I got a H22a OBDI.
A few days ago, I started to notice that I slowly lost some oil. Circa a quart per 250 miles. I couldn't see any smoke coming from the exhaust, so the leak had to be somewhere else. I looked under the car, but I couldn't find anything. However, I noticed that there were some oil patches on the tranny. It had me wondering a few days, until now when I saw that the oil was coming from the distributer. Once I removed the cap about 3 ounces poured out. Has this happened to anyone else, and how did you solve this problem. I'm assuming that a ring, or a seal has to be replaced, but which one?
I did a search and I got two responses. On https://honda-tech.com/zerothread?id=491984 there is a diagram, that might be helpful.
Thanks in advance.
Old Feb 26, 2004 | 08:52 AM
Revi's Avatar
Default Re: Oil in distributer. (-Bionic-)
#8 #6 look like it might be the problem. Check to see if your rubber cap next to the distributor is leaking too. That is know to bust also...did for me.
Old Feb 26, 2004 | 09:01 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: Oil in distributer. (Revi-Ra)
Thanks for the reply. Well what do you mean by the rubber cap?
How much do you think it will cost to have either, or both, of #6 and #8 replaced?
Thanks
Old Feb 26, 2004 | 09:19 AM
v4lu3s's Avatar
RTFM
the o-ring shouldcost very little, replacement is abotu 5 minutes with a 12mm socket, short extension and ratchet.
Old Feb 26, 2004 | 09:23 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: (v4lu3s)
The O-ring your referring to is item number 6, correct?
Thanks a lot.
Old Feb 26, 2004 | 11:11 AM
Revi's Avatar
The rubber cap im talking about is located at the left end side of the intake cam if you were to stand infront of your engine. Mine was leaking oil and ive heard of many others having this problem. I have noticed some oil stains near the distributor also, im curious about your dicoveries so i think im gonna check my distributor as well.
Oh yeah, the rubber cap costs like $2, and to replace it you need to take of the valve cover and intake camshaft plate and holder along with some liquid gasket. Easy to change.
Old Feb 26, 2004 | 11:21 AM
-Bionic-'s Avatar
Former Sponsor
hehe sounds easy alright, but I feel uncomfortable doing anything inside the engine. So, I will start by checking the distributer.
BTW, does anyone know how to get to the o-ring? I got an internal coil.
Old Feb 26, 2004 | 10:50 PM
-Bionic-'s Avatar
Former Sponsor
Hey guys. I posted the same topic in the tech forum, and the replies are different.
https://honda-tech.com/zeropost?cmd=tshow&id=780602
They tell me that I need to replace the distributor.
Please let me know what you guys think.
Thanks
Old Feb 27, 2004 | 04:19 AM
Filthy Focker!'s Avatar
I can't really talk about your particular seal problem here, but a good place to look for seals and orings are hydraulic shops... They have thousands, include metric ID with imperial OD....
Bearings, well a good bearing shop will get the bearing you need.... I get my beraings from a shop like that. I was even able to find engine beraings for very early HD shovelhead and knucklehead motorcycles...
fs
Old Feb 27, 2004 | 04:56 AM
v4lu3s's Avatar
RTFM
most often it is the o-ring.
if you want to go and spend a lot get a new distributor, but chances are its an o-ring that costs next to nothing and is easy to replace. and if you are nto comforatble doing it yourself have a mechanic take a look.
Old Feb 27, 2004 | 11:43 AM
-Bionic-'s Avatar
Former Sponsor
Thanks a lot. Good info. As far as the o-ring is it the same size in a US as in a JDM?
Thanks
Old Mar 7, 2004 | 08:09 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: (-Bionic-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Bionic- &raquo;</TD></TR><TR><TD CLASS="quote">Thanks a lot. Good info. As far as the o-ring is it the same size in a US as in a JDM?
Thanks</TD></TR></TABLE>
For those with similar problems. The o-ring and rotor is identical in JDM and USDM H22, however, the cap is different.
Also, the o-ring is not the problem. I'm looking for a new distributor. Anyone?
project93hatch
Jun 3, 2010 09:28 AM
Lithel
May 5, 2008 06:46 AM
Honda_Accord
Apr 7, 2008 09:32 PM
Budget Racer
29
Mar 29, 2008 12:05 PM
Drew Peacock
Mar 15, 2003 09:54 AM
