bolt tightening sequence for oil pan
i can see there is 4 bolts near transmision and i can see a backing bracket there.i think i remove to outer thus the trans bracket comes off.then after i unbolt and drop oil pan how do i put back together.i realize tightening seq is criss cross but how do i go about it.thanx
Ive had mine off countless times, and the pan bolts and nuts are only torqued to like 7ftlbs so I doubt any warpage would happen. As long as you have a good gasket I'd tighten them whatever is easiest for you, but I'd recommend doing the "star" tightening of them.
bopbop93030
Jul 4, 2009 06:40 AM
bout 2 do oil pan removal/install.. gettin all my procedure verified first so dont run into any dela
J.nguyen
Honda S2000
May 12, 2007 01:25 PM
