BOV, Wastegate, etc Installation question.. simple?
I'm almost done installing the Revhard kit, and I'm in the phase where I need
to connect all the vacuum tubing... I understand I'm supposed to put a T inline
from the factory FPR, and use that to run to the supplied FMU... Am I supposed
to also tap another one for the wastegate as well? AND the BOV as well?
[Modified by echo999, 8:16 AM 10/14/2001]
yea, that would work as well. you COULD tee everything off the fpr. but from ive read, its more acurate to tee the boost gauge and the bov to the brake booster line. get a golden eagle vacuum manifold, connect that to your brake booster line, and tee everyting off of that that.
go search, theres a plethora of info about the the brake booster vacuum line.
