help removing 4thgen prelude speakers with out opening door
Old Feb 25, 2004 | 08:24 PM
t0ekn3e's Avatar
Default help removing 4thgen prelude speakers with out opening door
does any one know how it would be possible to take out front speakers on a 4th gen prelude with out opening the door my friend got in an accidnet and cant open the door but he wants his speares out any help?
Old Feb 25, 2004 | 11:01 PM
@ries's Avatar
Default Re: help removing 4thgen prelude speakers with out opening door (t0ekn3e)
You can take out the speaker... but you would probably end up hacking the door panel apart to do so.
Old Feb 25, 2004 | 11:46 PM
t0ekn3e's Avatar
so just cut up the panels?
Old Feb 25, 2004 | 11:47 PM
@ries's Avatar
Default Re: (t0ekn3e)
Just try prying around the speaker grill... if that still doesn't work then start hacking away.
Old Feb 26, 2004 | 05:11 AM
cecknight's Avatar
Default Re: (emoBB1)
I"ve had to change my speakers out before. The only way I see it happening is if you remove the whole door panel.
It isn't that hard. Make sure all the snap buttons are popped out and the screws removed. Pop the screw out on the interior door lever and take the panel off. Once all that is done, you should be able to like up and back on the panel, it should pop right off...
...it was a pain the first time I did it b/c I had to feel it out.
Whats size speakers are you installing?
Old Feb 26, 2004 | 05:40 AM
OTT's Avatar
OTT
cecknight, he said the doors jammed!
t0ekn3e: If the sideof the cars sides' real mashed up just get a large crowbar and work your way around the edge of the frame an rip the beast off, but whatchout those doors will break your feet if they fall on u !!, Thats the only way i could see you getting them out !
Old Feb 26, 2004 | 07:43 AM
t0ekn3e's Avatar
im not installing removeing some mb quarts 6.5 compments and ill try to pry the door out with th crowbar thanks for the help
Old Feb 26, 2004 | 10:19 AM
cecknight's Avatar
Default Re: (OTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OTT &raquo;</TD></TR><TR><TD CLASS="quote">cecknight, he said the doors jammed!
t0ekn3e: If the sideof the cars sides' real mashed up just get a large crowbar and work your way around the edge of the frame an rip the beast off, but whatchout those doors will break your feet if they fall on u !!, Thats the only way i could see you getting them out !</TD></TR></TABLE>
My bad....need to quit the caffine .
The crowbar is what I would do then. If you can do it from the inside, you can use an electric hacksaw and cut the interior molding around the speaker. I'd start at the "bulge" above the speaker area just to get a visual on what else needs to be cut.
Old Feb 26, 2004 | 10:22 AM
del_parker's Avatar
try an angle grinder or sawzall and cut that part of the door panel off.
ricepower
Aug 10, 2004 07:37 AM
lude_si_95
Audio / Security / Video
Dec 28, 2003 02:17 AM
abolish415
Nov 24, 2003 09:46 PM
Mike banX
Nov 5, 2003 11:46 AM
Daemione
Aug 8, 2001 12:18 PM
