thought it was misfiring was wrong?!?!
Old Feb 25, 2004 | 06:46 PM
jagged4698's Avatar
Default thought it was misfiring was wrong?!?!
Ok what i thought was a misfire was completely off. So after changing out my plugs, cap, rotor, wires, and fuel filter (basic tuneup) my car still in all gears except first. So i ran the engine and i pulled out each wire one at a time and sure enough all of them gave the right amount of spark. So now i'm confused. I will try and put this as best as possible. I can accellerate with all my power in first gear. I shift into second gear and if i stomp on the gas it will bog down. If i gradually accelerate it will go just fine. And it does this for all gears except first... Any ideas??
Old Feb 26, 2004 | 03:39 AM
Filthy Focker!'s Avatar
Default Re: thought it was misfiring was wrong?!?! (jagged4698)
Just answered a post like this
https://honda-tech.com/zerothread?id=780453
fs
Old Feb 26, 2004 | 06:56 AM
jagged4698's Avatar
Default Re: thought it was misfiring was wrong?!?! (filthy_shovel)
well i have decided it is not my spark....i have run multiple tanks of gas through about 2 with SEAFOAM (fuel line/injector cleaner) so i'm guessing it is not bad gas. sso the only thing i have left to do is check my air filter and check my exhaust. Would it be safe to run with the air filter off around the block to see if that is my problem? It is an aftermarket air intake...if that is not the problem what kind of cat should i get? what would an oem one run me???
Old Feb 26, 2004 | 08:10 AM
Another thought: Carbon plugged EGR Ports (these can be cleaned), Honda has a TSB "Technical Service Bulletin" on this
Old Feb 26, 2004 | 05:17 PM
sponger1054's Avatar
mine was misfiring but its because i was missing a ground....check all your ground points to make sure its all grounded nicely
Old Feb 26, 2004 | 07:02 PM
jagged4698's Avatar
Default Re: thought it was misfiring was wrong?!?! (sponger1054)
Yeah i noticed i have had a ground wire that was snapped and i am pretty sure it has been that way for a year or more and has never given me any problems...i will replace it just to make sure but i doubt that is it?
Old Feb 27, 2004 | 07:12 AM
either way they dont just put wires on cars to not be attached...it is neccesary...hope it works for you man
Old Mar 1, 2004 | 03:20 PM
typertn's Avatar
sounds like either a bad ground or an o2 sensor
manintux
Jul 7, 2008 05:52 PM
pjr710
10
May 31, 2007 10:49 PM
blake22
Mar 29, 2007 05:51 PM
92greensr
Jan 17, 2004 09:53 AM
mookie
Mar 11, 2003 06:01 AM
