Building a CRX Help
Me and a close friend of mine are going to build a 91 HF for street and strip drag racing. We need something that isn't driven everyday but is able to drive into town and things like that. What setup would you use. We were thinking along the lines of a B18C5 or a CRVTEC but we haven't decided to go turbo or nitrous let me know what you guys think.
if you are going forced induction, the c5 is the last swap I would use. It cost to much $$,if your gonna boost you can boost anything and get it faster than a stock c5 and be cheaper. I would get a h22,build it up and do a LARGE nitrous shot. Or the same thing to a b20. Nitrous will get you into the 11's pretty fast!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMVTEC »</TD></TR><TR><TD CLASS="quote">but we haven't decided to go nitrous let me know what you guys think.
I do not like NO2 because it stretches everything and you will have to do more maintenance than you want too.
Well the H22 was a first though but from what I have heard it will be a pain to actually be able to drive that through town so I wam going to try and keep it B series. So B18B Turbo and forget the C5. Any other suggestions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sampsonite987 »</TD></TR><TR><TD CLASS="quote">H22A for drag, handling will be trashed.</TD></TR></TABLE>
not really. only weighs about 80lbs more then the b18
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sampsonite987 »</TD></TR><TR><TD CLASS="quote">H22a=dont plan on taking a turn at 90mph</TD></TR></TABLE>
dont take a turn at 90 with any motor
ls/vtec
ls/vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Hatchback »</TD></TR><TR><TD CLASS="quote">
dont take a turn at 90 with any motor </TD></TR></TABLE>
I wasnt being literal.
The H22 is a very big motor for a crx, dont get me wrong it is an awesome engine, but you would have to do a lot of modification and beef up your suspension, brakes, etc.... all that equals weight, same wth a b18 but worse with an H22.
Your weight ratio would horrible also.
The H22 is a very big motor for a crx, dont get me wrong it is an awesome engine, but you would have to do a lot of modification and beef up your suspension, brakes, etc.... all that equals weight, same wth a b18 but worse with an H22.Your weight ratio would horrible also.
Your weight ratio would horrible also.</TD></TR></TABLE>
he is running in a straight line. all he needs to do is upgrade the suspention. Something he has to do anyways.
The H22 is a very big motor for a crx, dont get me wrong it is an awesome engine, but you would have to do a lot of modification and beef up your suspension, brakes, etc.... all that equals weight, same wth a b18 but worse with an H22.Your weight ratio would horrible also.</TD></TR></TABLE>
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
h22 ---stright line racing, good for stright drag
c5----good for all motor drag, too high of compression for turbo really.....
I would go b20VTEC Fully Built Turbo....that me...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sampsonite987 »</TD></TR><TR><TD CLASS="quote">No replacement for displacement.
Why is it...
that everyone claims that the "technology" in Japanese cars is the replacement for displacement...
until something like this comes up...
and now its Theres no replacement for displacement?
</TD></TR></TABLE>Why is it...
but like I said before I am not only going to drive the car in a strait line. I want the car able to drive in town so if someone wants to run I can go to the house get it and drive it back. I am thinking about just a good ol B18C1 with a stroker kit that lowers the compression and a jackson racing supercharger or a rev hard turbo kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UrbanFuturistic »</TD></TR><TR><TD CLASS="quote">
Why is it...
Honda has lead the way when it comes to high rpm high horespower small engines. But look at the s2000, or the nsx. S2000=2.2 liter inline 4--- NSX=3.2 liter v-6. You cant deny that you will get more power with a higher displacment built motor (in most cases).
Honda upped the displacement of the 2000 for more power.
Why is it...
</TD></TR></TABLE>Honda has lead the way when it comes to high rpm high horespower small engines. But look at the s2000, or the nsx. S2000=2.2 liter inline 4--- NSX=3.2 liter v-6. You cant deny that you will get more power with a higher displacment built motor (in most cases).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMVTEC »</TD></TR><TR><TD CLASS="quote">but like I said before I am not only going to drive the car in a strait line. I want the car able to drive in town so if someone wants to run I can go to the house get it and drive it back. I am thinking about just a good ol B18C1 with a stroker kit that lowers the compression and a jackson racing supercharger or a rev hard turbo kit.</TD></TR></TABLE>
You would scream with that setup on street tires.
allenp
22
Sep 14, 2004 04:16 AM
