Engine burning oil insanely
Old Feb 25, 2004 | 04:52 PM
Sampsonite987's Avatar
Default Engine burning oil insanely
I did a search but nobody has the symptoms I do. 90 CRX hf stock motor, compression is 185-190 in all cylinders, it burns blueish smoke as soon as it starts up and continues when it is running, it has much smoke that comes out it is crazy, it looks like a chimney. I found a little bit of oil on all the spark plugs when I removed them. Any suggestions. Also the engine idles at 4000 rm and the ecu threw a code 14 (electronic air control valve) anybody have problems with this valve. Its not a huge deal if I cant use this motor cause I got another, but if anyone has had the same problem could you shoot me some ideas, Thanks
Old Feb 25, 2004 | 04:56 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Engine burning oil insanely (Sampsonite987)
bad/burnt valves maybe
Old Feb 25, 2004 | 04:59 PM
Default Re: Engine burning oil insanely (Hybrid Hatchback)
Well I thought maybe bad valves but would it burn that much oil , I mean it smokes so much you cant see when it is running. I am not sure , anybody else know?
Old Feb 25, 2004 | 05:08 PM
c for sea's Avatar
well, you're definitely burning oil, that's for sure because of the blueish smoke. i'd say piston rings but you have great compression in all cylinders. i have to agree with the bad valves theory. Have a leak-down test performed to double check.
Old Feb 25, 2004 | 05:51 PM
Default Re: (c for sea)
Whats wierd is that the engine never misses a beat. I will do a leak down test and see whats up, but shouldnt I have lower compression in at least on cylinder for the leak down to be accurate. I dont know, Ill mess with it and see what I come up with. Thanks
Old Feb 25, 2004 | 06:08 PM
green91's Avatar
mines got good compression too but burns some oil at like 5k+ rpms, just throw some oil some treatment in it and run her till she blows
Old Feb 25, 2004 | 06:10 PM
Default Re: (green91)
Mine doesnt burn some oil, no, it REALLY burns oil. I cant drive it unless I want to choke everyone on the block. HaHa
sacabon's Avatar
I'll bet your valve seals are bad.
Old Feb 25, 2004 | 06:12 PM
Default Re: (sacabon)
See thats what Im betting on, I am going to check it tomorrow and find out whats up.
93 EG
15
Sep 22, 2008 09:46 PM
Snoxxy
11
Sep 14, 2008 01:19 AM
WanaBeFaster
May 6, 2007 08:17 AM
preludeguy_92
Jun 25, 2005 11:39 AM
carcala
May 17, 2004 06:19 PM
