extended warranty 94-97 accord
Old Feb 25, 2004 | 04:30 PM
8krpm's Avatar
Default extended warranty 94-97 accord
does anybody know or heard of anything about the 94-97 extended warranty coverage until 150,000 miles for honda accord, i think it covers some kind of valve in exhaust ...because today i got my 90,000 mile tune up and the dealer said something about that and they'll change it for me for free tomorrow when they get the part...could this be related to the check engine light that i have one?
Old Feb 25, 2004 | 04:33 PM
nver2's Avatar
Default Re: extended warranty 94-97 accord (8krpm)
what o2 sensor maybe?
Old Feb 25, 2004 | 08:03 PM
cd555's Avatar
Honda did an extended warranty on certain 94-97 Accords which basically gave a 7 year 140,000 mile extension. Which means that this should not be in affect anymore seeing as how the 97 model year is 7 years old. This is just what the paper that I got from Honda said, but you might want to call Honda and check for yourself.
Old Feb 26, 2004 | 06:57 AM
fw190bvi's Avatar
Default Re: extended warranty 94-97 accord (farroutt)
there was an extended waranty on something exhaust related..i believe it was related to a buzzing sound coming from the piping
Old Feb 26, 2004 | 04:02 PM
madiaz's Avatar
i believe that on emmisions components, catalytic converters oxygen sensors etc..
thay are covered by a federal regulation
the dealer in florida tried to swindle my sister when her header cracked. she has a civic with the header and cat as one unit (lx)
i went to the dealer up here and they produced a document that on her civic it was an 8 year federally mandated warranty.
i am unsure about you're year accord but i do know that emmisions parts that are federally regulated are a bit different than a normal warranty.
regards,
m.a..d
Old Feb 26, 2004 | 04:19 PM
RotaryBzzzz's Avatar
Default Re: extended warranty 94-97 accord (madiaz)
it's in my emission thread 2nd page.
Old Feb 26, 2004 | 04:43 PM
bill-71SS's Avatar
Default Re: extended warranty 94-97 accord (RotaryBzzzz)
95 -97 accords are emmission warranty update for 150.000 miles on any emission related part.
Old Feb 26, 2004 | 04:51 PM
mwkirchner's Avatar
Default Re: extended warranty 94-97 accord (bill-71SS)
THE FOLLOWING APPLIES ONLY TO THE FOLLOWING CARS:
1995 Accord V6 – ALL
1996 Models except Passport – ALL
1997 Models except Passport – ALL
THIS IS DIRECTLY FROM THE EMISSIONS WARRANTY EXTENSION BULLETIN #98-081 FROM HONDA
WARRANTY EXTENSION INFORMATION
American Honda is extending the emissions warranty on all affected vehicles to 14 years or 150,000 miles, whichever comes first. The basic terms of this extended warranty are the same as given with the original Federal and California emissions warranties.
Federal Emissions Warranties
The time and mileage periods for the Emissions-related Design and Defects Warranty and the Emissions Performance Warranty are lengthened from 4 years or 50,000 miles to 14 years or 150,000 miles. All other terms, conditions, and exclusions still apply. All parts on the Emissions Parts List are now covered for 14 years or 150,000 miles, so the 8/80 notations on certain parts no longer apply.
California Emissions Warranties
The time and mileage periods for the Emissions Control Systems Defects Warranty and the Emissions Performance Warranty are lengthened from 4 years or 50,000 miles to 14 years or 150,000 miles. All other terms, conditions, and exclusions still apply. All parts on the Emissions Parts List are now covered for 14 years or
150,000 miles, so the 7/70 notations on certain parts no longer apply.
HERE IS A LIST OF SOME OF THE PARTS THAT ARE COVERED UNDER THIS WARRANTY
VTEC SOLENOID, VTEC PRESSURE SWITCH, INTAKE MANIFOLD and /or GASKET, DISTRIBUTOR, DISTRIBUTOR SUBASSEMBLY, IGNITION CONTROL MODULE (IGNITER), IGNITION COIL, SPARK PLUG WIRE SET, DISTRIBUTOR IGNITION CAP and/or ROTOR, SPARK PLUG, PGM-FI ENGINE/POWERTRAIN CONTROL MODULE (ECM/PCM), PGM-FI MAIN RELAY, OXYGEN SENSOR, MANIFOLD ABSOLUTE PRESSURE (MAP) SENSOR, ENGINE COOLANT TEMPERATURE (ECT) SENSOR, THROTTLE POSITION SENSOR, THROTTLE BODY, INTAKE AIR TEMPERATURE (IAT) SENSOR, CRANKSHAFT POSITION (CKP), TOP DEAD CENTER (TDC) or CRANKSHAFT SPEED FLUCTUATION (CKF) SENSORS MOUNTED ON CRANKSHAFT PULLEY SIDE OF ENGINE or CAM COVER, CRANKSHAFT POSITION (CKP), TOP DEAD CENTER (TDC) or CYLINDER POSITION (CYP) SENSORS MOUNTED IN DISTRIBUTOR, VEHICLE SPEED SENSOR, KNOCK SENSOR (KS), ELECTRIC LOAD DETECTOR (ELD), FUEL TANK PRESSURE SENSOR, EXHAUST GAS RECIRCULATION (EGR) VALVE, EGR PORT - Clean, EGR CONTROL SOLENOID VALVE, EGR VACUUM CONTROL VALVE, IDLE AIR CONTROL (IAC), INJECTOR (Any or all), INJECTOR RESISTOR, FUEL PRESSURE REGULATOR, FAST IDLE THERMO VALVE, STARTING AIR VALVE, POSITIVE CRANKCASE VENTILATION VALVE (PCV), PURGE CONTROL SOLENOID VALVE, EVAP CANISTER VENT SHUT VALVE, EVAP CONTROL CANISTER, EVAP TWO-WAY VALVE, FUEL TANK VAPOR CONTROL VALVE, TRANSMISSION CONTROL MODULE (or PCM), MAINSHAFT SPEED SENSOR, COUNTERSHAFT SPEED SENSOR, PRESSURE CONTROL LINEAR SOLENOID VALVE, LOCK-UP CONTROL SOLENOID VALVE ASSEMBLY, SHIFT CONTROL SOLENOID VALVE ASSEMBLY (Any), A/T GEAR POSITION SWITCH, FUEL TANK, FUEL FILLER NECK, FUEL TANK FILLER CAP, EXHAUST MANIFOLD or GASKET(s), CATALYTIC CONVERTER.
Modified by mwkirchner at 9:13 PM 2/26/2004
ssmig
Jun 11, 2017 12:06 PM
mizzolini
May 2, 2008 06:06 PM
HondaAccordSE1997
Jul 10, 2007 05:38 AM
H23vtecEG
Acura TSX
Mar 21, 2006 01:57 PM
Accord95_H23A1
Dec 6, 2005 08:27 AM
