oil on the plugs....
Old Feb 25, 2004 | 04:23 PM
ernestoG's Avatar
Default oil on the plugs....
so I'm trying to figure out what's causing a lean condition on my h22a. Changed plugs today and there is oil on them...well one of them and it seemed like a lot to me...I tried searching and Fomr what I read it's usually the valve cover gasket, but could this also be caused by a toasted valve? And couldn't that cause a lean condition? Here's a pic of the plugs.
Old Feb 25, 2004 | 04:38 PM
ryanstev's Avatar
It can also be caused by over filling your engine with oil and leaks past your piston rings.
Old Feb 25, 2004 | 05:11 PM
Matgallis's Avatar
Default Re: (ryanstev)
In my Chilton Manual it says
"An Oil Fouled Spark plug indicates an engine with worn piston rings and/or bad vavle seals allowing excessive oil to enter the chamber."
Old Feb 25, 2004 | 05:30 PM
Behan's Avatar
Default Re: (Matgallis)
my guess would be the sprark plug grommets. they are easily replaced by pulling the valve cover and cost about 2.00 bucks. you can use http://www.slhondaparts.com to see a pic and get the part number. check these first as these are most likely the culprit.
Old Feb 25, 2004 | 05:47 PM
Matgallis's Avatar
Default Re: (Behan)
I just remember when My hg went bad on my Acura, the spark plug looked like yours on the left.
Old Feb 26, 2004 | 01:38 PM
ernestoG's Avatar
thanks all...i'm gonna try the gromets first..I've been following the best cams for n/a thread and it's got me thinking about doing something to the head but I'm not ready yet so I hope the gromets do it.
Also if I had bad rings wouldn't I be smoking all the time?
Modified by ernestoG at 6:08 PM 2/26/2004
Old Feb 26, 2004 | 03:03 PM
DW's Avatar
DW
Default Re: (ernestoG)
i doubt it will the be the valve cover grommets because the top part of the plugs would be covered with oil not the bottom
possibly causes:
piston rings
valve guides
valve stem seals
headgasket
do a compression and leakdown test and see what numbers you get. that might lead you to the problem a lil better
David
Old Feb 26, 2004 | 03:34 PM
Behan's Avatar
Default Re: (DW)
well when i first got the car, the no.4 spark plug looked exactly like the furthest one in on his pic. i replaced the grommet and the problem was fixed.
it is a fairly common problem, as most people don't replace them everytime they pull the valve cover off, like honda suggests. **** i know your supposed to and still don't, i just replace them as needed
Old Feb 27, 2004 | 03:03 PM
DW's Avatar
DW
Default Re: (Behan)
one way to tell if its the valve cover grommets is to look down the spark plug holes and see if theres oil in them. if not then i doubt its the grommets because it is impossible for oil to get into the combustion chamber via the valve cover grommets. if the grommets are leaking then there will be oil inside the holes and on the top part of the spark plug where the wire attatches to the plug.
David
Old Feb 27, 2004 | 05:53 PM
mikesterny's Avatar
Default Re: oil on the plugs.... (ernestoG)
my plugs looked like that every time i've pulled them one friend said they will look like that because all hondas burn a little oil when under high rev/vtec another friend said it was running too lean but i had my car checked out and it wasn't runnin too lean at all the only solution i got from anybody was to change plugs every 10k to keep performance high because of fouled up plugs
Old Feb 27, 2004 | 06:16 PM
Behan's Avatar
Default Re: (DW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DW &raquo;</TD></TR><TR><TD CLASS="quote"> if the grommets are leaking then there will be oil inside the holes and on the top part of the spark plug where the wire attatches to the plug.
David</TD></TR></TABLE>
actually the oil would be on the spark plug wire connector, not the top of the plug. just clarifying what you said.
the grommets are only like two bucks and need to be replaced periodically anyway. which is why i recommended it as the first thing to try.
Old Feb 27, 2004 | 07:04 PM
ernestoG's Avatar
Default Re: (Behan)
ok well i cahnged the plugs and the car is still running lean...T'm gonna pull the plugs tomorrow morniing and have a look and see if it's on the bottom of the plugs. I already order the gromets, but I'll keep em lying around. I'm also gonna try and find a compression checker thing and check that tomorrow also.
Old Feb 27, 2004 | 08:15 PM
InjectedPerformance's Avatar
We sell parts.
Well it could be the valve seals
This is the best tool invented to replace them
http://buy1.snapon.com/catalog...+Tool
Thank me later
Old Feb 27, 2004 | 08:18 PM
We sell parts.
Default Re: (primo8998)
Just blow some compressed air (100 psi) into a cylinder. Seriously, it will only take you 1 hour tops to replace the seals. Of course when you get the cams and stuff off.
Old Feb 28, 2004 | 01:05 PM
ernestoG's Avatar
ok compression seems good 220lbs (17 kpa*1000) on all cylinders.
I'm throwing a code but I don't know if it's a 1 and a 10, (one short blink followed by one long) I think it is and that would explain the shity readout on the a/f (cause the 1 is the oxygen sensor right, and would the intake temp sensor make the car run poorly?). but there's was some oil on the #2 plug in the threads of it.
Old Mar 1, 2004 | 06:44 PM
ernestoG's Avatar
Old Mar 1, 2004 | 06:52 PM
ensracer's Avatar
if there is carbon build up fouled plug its what they said if there is oil on the plug and you have good compression try getting a valve job. there can be excessive gap in the valves.... i did my own valve job and this was fixed
banks358
Dec 27, 2009 08:26 PM
keyknow
May 30, 2009 08:02 PM
dismemberment
Feb 18, 2009 02:51 PM
sacredc0w69
May 24, 2003 06:34 AM
respectblades
Apr 2, 2003 06:26 PM
