Calling all DOHC ZC Owners
Old Feb 25, 2004 | 12:37 PM
integ u's Avatar
Default Calling all DOHC ZC Owners
My car is in the shop getting the motor put in right now.
I have ZC motor with the ZC ecu and ZC 5spd tranny
I just had some questions about this motor.
I plan on staying NA
Where does the powerband start and end at on stock cams?
What was the best mod u added to your ZC,and noticed butt dynoed and on the dyno
What cars can u guys beat or keep upo with?
What should my 1/4 times look like?
BTW i have a 90 civic STD the back is gutted and it has no AC stuff in it
Is the DH racing ZC to LS line bore head worth buying? WHo has it?
Should i beable to crush all other D series vtec's and nonvtec's stock.
Anything i should known or do please tell me. Thanks
Old Feb 25, 2004 | 12:42 PM
CrowerRex's Avatar
Default Re: Calling all DOHC ZC Owners (integ u)
http://www.thezcresource.com
All you need to know is here
Old Feb 25, 2004 | 12:52 PM
integ u's Avatar
Default Re: Calling all DOHC ZC Owners (CrowerRex)
i've been to almost everysite goggle has gave me
i need more detailed info and personal experiance about this motor than just the parts list that just about every ZC site has stolen from eachother and what this motor fits into.
That was helpful when i was a nubie.
not any more
Old Feb 25, 2004 | 12:54 PM
GoFastMotorSports's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integ u &raquo;</TD></TR><TR><TD CLASS="quote">My car is in the shop getting the motor put in right now.
Anything i should known or do please tell me. Thanks</TD></TR></TABLE>With these questions,you still are a noob.
Old Feb 25, 2004 | 01:02 PM
out_of_order's Avatar
ive heard that SI tranny work better then the ZC tranny..mayb you should throw that in ..but this is one D-serise you wont beat
CrowerRex's Avatar
Here are A's to your q's
Where does the powerband start and end at on stock cams? starts at about 4000 and ends at 6900-7000.
What was the best mod u added to your ZC,and noticed butt dynoed and on the dyno? Added a jdm b16a down pipe portmatched to the zc upper manifold, gave good top end increase. Short ram intake and free flowing muffler worked well also.
What cars can u guys beat or keep upo with? Depends on setup, stock integras (non vtec) with I/H/E and civics. Cavaliers (quad 4) and sunbirds (turbo or 3.1 5spd) ...the list goes on.
What should my 1/4 times look like? Mid to high 15's. I have my zc in a 90 civic si.
Ohh and the ls/zc head machining is a waste of $$$. Tune your zc with exospeed camshafts and valvetrain and you'll be geared. Remember though, the faster you want to be the more $$$ it is going to cost. Look at what you want to do with the car and go from there.
Hopefully this helps you.
Old Feb 25, 2004 | 01:13 PM
therealciviczc's Avatar
Get some experience behind the wheel of the car and find some of this stuff out. You can't just expect to know a motor from what people tell you.
As for the powerband, look at some ZC dynographs. My old one from when I first had my ZC showed my power holding really level clear out to redline.
I think the best mod for the motor is going to be cams if you're not going to go turbo. Personally I would say go turbo.
You can beat some similar cars. You're not going to be beating turbo'd 4 cylinders, or sporty cars that are V8 powered for the most part.
I'm going to go a little lower on the 1/4 mile times and say low 15s. I ran pretty much conisitent 15.3s at one track and 15.5s at another. This was in a 91 Si Civic. I had the Si trans so higher 15s might be more accurate with the ZC trans.
I used to race a friend of mine with a 92 Si hatch, I/H/E, flywheel, etc, and I was easily faster than that car with my ZC basically stock in an Si. I've since driven other ZCs and hey haven't felt as fast as mind did, so I may have just been lucky, but you should be able to beat just about any stock D series motored car since I think that 1992-95 Civics were the quickest D series cars in this country usually running high 15s.
NOTE: All times are general/average/common and no one cares if so and so's boyz neighbors uncle had a bone stock D15 that ran 11s in a CRX uphill with bricks in the back.. that isn't the point. Someone always has to post something like that!
Old Feb 25, 2004 | 03:06 PM
*Boostwerks*'s Avatar
Come on over to theZCR.com
All the info you ever need is in our forum...
Old Feb 25, 2004 | 03:30 PM
azulito's Avatar
Default Re: (Bryson)
thezcresource is not a copy, it is the real thing. Good luck.
Old Feb 25, 2004 | 04:11 PM
Garrett's Avatar
ZC Ressource for life
Old Feb 25, 2004 | 05:32 PM
c for sea's Avatar
http://www.thezcr.com
the ZC resource is the best.
Old Feb 25, 2004 | 05:39 PM
RussHondaCRXVtec's Avatar
the best mod is to get a real motor like...... a b series..... its better don't let anybody say that it isn't.....
Old Feb 25, 2004 | 07:32 PM
blah13's Avatar
Default Re: Calling all DOHC ZC Owners (RussHondaCRXVtec)
Get exospeed cams, world of difference. You can spank most stock v6 stangs n such, any stock D series civic, a good bit of stuff. Get those cams, i/h/e and youll be hangin with the stock v8 boys. You'll need more compression or turbo to hang with the modded v8 crowd though.
Old Feb 25, 2004 | 09:00 PM
Jaydo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integ u &raquo;</TD></TR><TR><TD CLASS="quote">dyno
My zc crx hf runs a 15.2 with I/H/E. I am dead even with my friends gsr with I,H/E/Pulleys and short shifter(But he has a 10'' rocksford sub in). I can usually beat a lightly modded 5th gen prelude but never raced a 4th gen. I also beat a civic si, gts celica, and im not sure but i think i can beat a 94 gt 5.0 auto.(Beat someone who beat one) Just experiement, but be careful.
Old Feb 28, 2004 | 01:11 PM
Project91CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RussHondaCRXVtec &raquo;</TD></TR><TR><TD CLASS="quote">the best mod is to get a real motor like...... a b series..... its better don't let anybody say that it isn't.....</TD></TR></TABLE>
Come on man.. this guy asked for ZC info... Not what motor is better than what motor...
Old Feb 28, 2004 | 02:56 PM
99EKhatch's Avatar
dont put people down...real motor?
i raped a b17 gsr std with my dohc zc crx...
driver?
probably but it still proves a point
RACEPAK
May 18, 2005 11:03 PM
crxsijr
Apr 15, 2005 12:58 PM
LSVTECKING
Sep 10, 2003 10:13 AM
DarkZachiel
10
Sep 2, 2002 10:09 AM
