JDM FogLight Wiring Question ( I alread searched)!
Ok, i searched but im not very good at electronics in the 1st place.
I have the JDM front with the fogs obviously, right now, i have a generic switch setup to a relay.
The switch has a Ground/Power/Switch Input..
My JDM Foglight has 5 wires...!
Red with Silver Dots
Red with Black Stripe
Black with Silver Dots
Green with Silver dots
Black with yellow Stripe
Can someone please help me!
Id like to just wire thes 5 into the 3 i had before, because i had to pay a shop to do the relay's and stuff.. (i have no idea whats the purpose of them or anything)
Thanks!
Thanks!
i found that link quickly also, but being a wiring begginner- And my wires are totally diffrent color from the uk harness...I dont know where to start..?
that link didnt give to much help because of this...
er the jdm fog light does not have 5 wires...
the jdm HID headlight has a harness that has 5 wires (ground/low/high/city/fog). ONE of those connectors is for the fog...
then you use that 1 (x 2 for both sides) wires (for the fog) and hook it up to a relay... then you can hook it up to the switch...
Ok- All my wiring is perfect-
Im putting in a JDM FOG Light Switch, in the spot of the Brightness control
It is plugged in by a Cruise control harness with those wires..
I need to connect it to a Power/Switch/Ground (generic switch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swags04 »</TD></TR><TR><TD CLASS="quote">
so do you have the relay installed, and all you need is the switch? Does your switch illuminate? If so, try this- use a 9v battery, attach one to ground, and the other to one of the other two wires on the switch. If the switch illuminates regardless of whether it's on/off, this 2nd wire is the "switched output". If the switch illuminates according to the position of the switch, then that wire is the "switched input". Here's a link to my USDM switch how-to, maybe it will be more helpful for you https://honda-tech.com/zerothread?id=685131
Can you take pictures of your switch and harness?
I already have my relay installed, and i already have a switch. Its an allumanated one also...
BUT ITs just a Pepboys 3 Prong one (power, ground, on/off)
I want to convert those 3 wires to my 5 wire JDM ITR Fog light button with cruise harness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swags04 »</TD></TR><TR><TD CLASS="quote">Anyone</TD></TR></TABLE>
Just look at the diagram and match up the pin locations... it's not rocket science you know
The writeup says that the colors wont match but the pin locations will...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swags04 »</TD></TR><TR><TD CLASS="quote">I already have my relay installed, and i already have a switch. Its an allumanated one also...
I want to convert those 3 wires to my 5 wire JDM ITR Fog light button with cruise harness</TD></TR></TABLE>
yeah if thats the case then that diagram in the link someone referred to earlier wlil do the trick.. dont worry about the color of the wires... not that many wire/pin locations to get confused over
jdeemseerx
Jan 28, 2007 04:34 PM
jdmspoonitr
Sep 9, 2003 11:09 PM
JDMTEG98
Sep 1, 2002 07:04 AM
