Strut/Sway bars...etc?????
Old Oct 13, 2001 | 02:32 PM
Calavera's Avatar
Default Strut/Sway bars...etc?????
I'm confused which one goes where.
Whats those bars called that go above the shocks/engine?
What are those called that go below the car? I've seen DC and neuspeed letters on 'em..if that helps.
What are those that go in the trunk?
And finally, any recommendations on what setup to go for a very good handling car? Do I really need bars that go in the trunk? Will there be a huge difference?
Should I install shocks/springs first?
Old Oct 13, 2001 | 03:08 PM
Malice's Avatar
New User
Default Re: Strut/Sway bars...etc????? (Calavera)
all bars over the shocks are strut bars. the smaller one on the bottom is a lower tie bar. the sway bar on a stock integra is the bar right aboue the tie bar. if u have a non Type R, its that skinny bar paralell(sp?) to the sub frame. Type R's have a much beefeir one.
and yes thay make a huge difference in handleing
Old Oct 13, 2001 | 03:29 PM
Leimokei's Avatar
New User
get a front strut bar, and rear strut bar and thicker rear sway bar, adjustable shocks and adjustable springs...best combo.....
companies i recommend, ITR sway or Suspension Technique or Comptech...
springs : H&R, eibach and APEX
shocks: Bilsteins, Koni Yellow, Tokico Illuminas, KYB AGX
Old Oct 14, 2001 | 12:24 PM
Calavera's Avatar
Default Re: Strut/Sway bars...etc????? (Leimokei)
I was planning on Eibach Prokits/KYB AGX adjustable(?) shocks.
ITR/comptech rear sway bar.
H&R and Koni Yellows is way to expensive....and they lower too much I think.
Front strut br and rear strut bar I havent decided on yet....
I'm gonna try suspension techique and comptech...thanx.
Old Oct 14, 2001 | 12:38 PM
Prelussion's Avatar
How goos does a rear lower Tie bar work?
Old Oct 15, 2001 | 09:52 AM
Malice's Avatar
New User
Default Re: Strut/Sway bars...etc????? (Prelussion)
you wont feel a difference with it if u have it.
Old Oct 15, 2001 | 10:33 AM
Calavera's Avatar
Default Re: Strut/Sway bars...etc????? (MaliceGSR)
I also heard that when you get a very stiff rear sway bar without re-inforcing it, it will rip the pannels or something?
TypeR sway bars are 22mm, right?
Although DC's looks cool, some people say the holes in the middle are just plainly for looks and actually decrease their performance....
Old Oct 15, 2001 | 11:03 AM
lildrgn2.0's Avatar
New User
do a search for my name starting a topic. I posted about this a while back and there are a lot of good explanations in it.
Old Oct 15, 2001 | 02:00 PM
Stephen's Avatar
Default Re: Strut/Sway bars...etc????? (Lildrgn)
Yes, the ITR bar is 22mm. And, yes, if you do not reinforce the subframe you can tear it with a bigger bar.
With a rear lower tie bar, your car may be a little stiffer, but it will not really handle all that much better...the tie bars and stuff really help with the responsiveness by reducing chassis flex. Solid bars are better than ones that are hollow or have holes. Billet aluminum is probably the best material because of its high strength and low weight.
Old Oct 15, 2001 | 02:03 PM
project_DC2's Avatar
Default Re: Strut/Sway bars...etc????? (Stephen)
GET ALL SPOON SUSPENSION!!!
ONE OF THE BEST!!
Nicks95GSR
Feb 29, 2008 04:13 PM
s2k_3.11
Feb 28, 2007 05:45 PM
noob with an RS
Nov 13, 2004 01:28 PM
Greg James
Jul 30, 2004 12:55 PM
IgniteTeg
Sep 11, 2001 02:02 PM
