HELP HELP HELP~!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!
Old Feb 25, 2004 | 06:02 AM
lYellowDragonl's Avatar
Default HELP HELP HELP~!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!
i was wondering if anybody knows why check engine light is on its a 89 CRX with a b16a engine from a integra GSX from japan the computer isnt throwing any numbers and also theres a rough idle anyone know please help
Old Feb 25, 2004 | 06:11 AM
Filthy Focker!'s Avatar
Default Re: HELP HELP HELP~!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!! (lYellowDragonl)
Couple of questions first:
Is the idle rough all the time?
Can it rev higher that 3000 rpms or so?
check the oil, is it low?
Is the idle moving up and down...
PROBABLE CAUSES:
1. The engine's computer has detected a problem in the system.
2. The engine has a serious problem that should be repaired at once.
3. The engine's oil pressure is exteremely low.
4. The engine is overheating.
You have to look for the obvious first... Connectors, wires and that sorta thing
FS
Old Feb 25, 2004 | 06:14 AM
MonkeyMagic's Avatar
your ecu is defunct... get a new one
Old Feb 25, 2004 | 06:24 AM
Default Re: HELP HELP HELP~!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!! (MonkeyMagic)
the ecu was throwing throttle body errors i think it was error 14 but after replacing the sensor it fixed
Old Feb 25, 2004 | 06:51 AM
Default Re: HELP HELP HELP~!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!! (filthy_shovel)
im not the installer my friend is, he doesnt want to let it run i been trying to tell him let it run for like 15 mins because it been sitting there right? it has brand new oil in it and has platium spark plugs in them id be sure to tell him do you think it will break or blow the engine if i rev the engine to 3000rpm? thanks
Old Feb 25, 2004 | 07:19 AM
b16_madman's Avatar
I don't know. Hope you get it right.
Old Feb 25, 2004 | 07:21 AM
Default Re: HELP HELP HELP~!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!! (B16_madman)
Was this a simple engine swap, or a complete teardown and rebuild...
If it was engine swap, and the engine was running ok before, then you cold let it idle and rev it up...
fs
Old Feb 25, 2004 | 12:12 PM
it wasnt no rebuild i bought it from a store where they import japan engines and i bought it there has only 30k miles on it which i dont truly believe but i donno hit me up thanks~!
925EKCOUPE
Jun 21, 2009 12:52 AM
93H22
Mar 13, 2008 11:32 AM
tenpercenter
May 23, 2006 08:32 AM
0 0 0
30
Dec 18, 2002 06:25 PM
