LS/VTEC question??????
Old Oct 13, 2001 | 12:48 PM
ysrhatch's Avatar
New User
Default LS/VTEC question??????
i just rebuilt my block and theres a problem, well there was a lot of problem but i cut it down to just a few. well this is what happen, when the car starts it idles fine at 800 to 900 rpm. but what i dont understand is that when i shut it down and open the valve cover how come it start to smoke up. it doesnt smoke a lot but just a little. i try taking the car out for a drive to see how it performs but it laggs and wont go anywhere. i gives me a code of 22 (which is the oil pressure sensor) i check that it was cool. what whould you guys perferr me doing??? im confuse and i invest a lot of money into this block. please help???
Old Oct 13, 2001 | 06:25 PM
paulzy's Avatar
Default Re: LS/VTEC question?????? (ls_vtecer)
are you even getting oil pressure? you have a friend with a honda? They share the same oil pressure sender...try their's
Old Oct 15, 2001 | 07:44 AM
badCRX's Avatar
New User
Not sure which ecu you are running but codes 21 and 22 are usually related to the VTEC solenoid and the VTEC oil pressure sensor. Can't remember which is which right now. Are you sure the wiring is correct and that the sensor is good?
Old Oct 16, 2001 | 10:11 AM
ysrhatch's Avatar
New User
Default Re: LS/VTEC question?????? (badCRX)
well before i was using a pr3 ecu but now im using a 90 ls. now its giving me a code 32 or 33 which i dont know what it is. but the car does not have a oil light on.
Old Oct 16, 2001 | 03:23 PM
paulzy's Avatar
that might be vtec solenoid....or vtec oil pressure
Old Oct 16, 2001 | 07:34 PM
rainforest's Avatar
Default Re: LS/VTEC question?????? (Slow_ass_4dr)
check you vechical speed sensor. Your spedometer cable. Clean your selinoid screen. thas what i bet it is.
Old Oct 17, 2001 | 07:41 AM
pstreck's Avatar
New User
Default Re: LS/VTEC question?????? (rainforest)
22 is the vtec oil pressure code, check your vtec oil pressure sensor.. the car will lag if the engine is to cold or the vtec oil pressure is to low.
Old Oct 17, 2001 | 07:49 AM
3.3.3's Avatar
Default Re: LS/VTEC question?????? (pstreck)
a little smoke is normal.
Old Oct 17, 2001 | 11:41 AM
ysrhatch's Avatar
New User
Default Re: LS/VTEC question?????? (spnhb)
cool i thought smoke will cause a problem. but if the pressure is low how will i go upon increasing the pressure. i check everything and it seems like everything is installed and working find.
HONDRETTI
11
Jan 26, 2009 02:40 PM
vladd
Jul 10, 2008 05:03 PM
chachi1080p72
Nov 16, 2007 04:20 AM
calhoun
Nov 2, 2006 05:49 PM
itz_nij
Aug 9, 2006 03:02 PM
