Different ways to install JDM front end.
Old Feb 24, 2004 | 10:10 PM
deepgreengsr's Avatar
Default Different ways to install JDM front end.
Hi, I want to install MY JDM front end on my teg. I have seen a few different ways to install it. Some people replace the whole rad support. Some install it by just replaceing the upper crossmember. I am not sure on the best and most effective way. I am good at welding and have no probelms doing that. I have never really done body work before and dont have experience with removing crossmemebers etc.
Does anyone have a good write up or pictures of what it shold at least look like on a quality install? Thanks.
Old Feb 24, 2004 | 10:14 PM
slowww b18b1's Avatar
Default Re: Different ways to install JDM front end. (deepgreengsr)
if u go to http://www.teamintegra.net they have a real nice step by steo instruction post on how to do it...
Old Feb 24, 2004 | 10:25 PM
six_speed's Avatar
the theory behind only removing the top portion of the radiator support is that the less spot welds that is drilled out; the more stable it's when compared to removign the whole radiator support.
in other words the lower radiator support still retains its integrity.
Old Feb 24, 2004 | 10:50 PM
B U N M A N G O's Avatar
I've seen another thread here where they used the USDM reinforcement bar. You might want to do that as well.
Old Feb 24, 2004 | 11:06 PM
JadeDM's Avatar
http://tech.wiredspeed.com/jdm_front.asp
Old Feb 25, 2004 | 10:59 AM
ECKOTYPER's Avatar
i personally did the top croos member and the middle part, its suppost to be the t of the support that u change, and i thought it was very easy, compared to doing the whole support and maybe not getting it straight, also i did not weld my t to my old support, mines a complete bolt on kit, so u can go that route, just to let you know, it looks good =D and its all bolt on =D so i can go back to the stock usdm itr front if wanting to =D
Old Feb 25, 2004 | 05:27 PM
Default Re: Different ways to install JDM front end. (ECKOTYPER)
cool. so instead of filling in the spot welds, did you bolt the parts together? Im haveing trouble seeing how it's all bolt in.
Old Feb 25, 2004 | 11:20 PM
ECKOTYPER's Avatar
yes thats exactly what i did, i believe i have 5 1/2 inch bolts 1 inch long, with washers and lock nuts holding it on, took much less time then it would to weld, and onyl 3$ in parts from home depot
Old Feb 26, 2004 | 01:06 AM
PlastikOwl
Guest
Posts: n/a
duck tape
sikciv666
Dec 8, 2012 06:24 PM
butyeaa
May 6, 2010 08:54 AM
JDMDC2BOY12
Feb 11, 2008 08:33 AM
odogg726
Sep 9, 2007 08:20 PM
