has anyone ran a crx with a gsr motor in it.
A guy i know with a civic hb, 92+ style, ran 13.7 with a jdm gsr, and just i/h/e. I was amazed, so im sure the crx should pull close to that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alld16a »</TD></TR><TR><TD CLASS="quote">mid 13's with bolt ons</TD></TR></TABLE>
i would say mid 13s but ill let you know in a bit. I talked to someone who had ran like 13.0 flat on here i forget who with a b18c1. Here is my setup and I just want to get into the 13s
b18c1
pnp head
3 angle valve job
head milled .020
convert to ob1 using p28 skunk 2 chip
skunk 2 manifold
jdm 4-1 header with 2.5 collect (port matched)
kteller 2.5 pipe
magnaflow muffler
2.5 high flow cat
skunk 2 intake manfiold (port matched)
ebay short ram intake with 3 inch pipe
hawker battery
quiafe lsd with 94 gsr tranny
hasport mount kit and linkage and axles
i think thats it. i was going to go crazy but i think i would kill myself i think this setup should keep me 13s and ill be happy with that.
DEF
b18c1
pnp head
3 angle valve job
head milled .020
skunk 2 manifold
kteller 2.5 pipe
magnaflow muffler
2.5 high flow cat
hawker battery
DEF
I can wait to run my CRX using B18C5 with JDM lsd YS1. The only mods i'll be running are a set of Edelbrock cams and valvesprings, and a aebs intake manifold. I have an intake and exhaust too, but i don't think they do much for quarter mile times.
not think..i know..something you wouldnt ever understand...especially since you're running a ZC
*Nothing against ZC's...Only to this flamer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMGSRCRX »</TD></TR><TR><TD CLASS="quote">not think..i know..something you wouldnt ever understand...especially since you're running a ZC
he wasnt talking to you...if you look who he replied to you would see its to mcdade
</TD></TR></TABLE>he wasnt talking to you...if you look who he replied to you would see its to mcdade
i HAD a jizzer in my rex...but i sold it...and i do miss it....One mistake i will always regret....
Definitely go with the GSR....
Chris, I knew i should have bought yours.
</TD></TR></TABLE>Chris, I knew i should have bought yours.
That's one SEXY CRX
</TD></TR></TABLE>That's one SEXY CRX
hows the hood clearance on that motor..
</TD></TR></TABLE>hows the hood clearance on that motor..
Hood Clearance was fine...I was using the JDM SiR front end and the bump on the hood cleared the motor fine...I was also running MAD engineering mounts as well.....
Sorry for the large size of the images....Call me lazy...
maybe i should toss out the b16 block and swap over to a gsr block with ITR pistons. Wonder how much of a gain that would get me? I know the torque would be noticable..
Meh..cheaper to turbo the d. The gains will be the same, but you'll be able to get more power quite easily.
Depends on if your all motor or not.
That was the setup i ran...ITR pistons in a GSR block...nice difference, only thing i was lacking were cams to get the full potential of the ITR pistons....but if i could do anything different i would have just gone turbo with my geezer.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxintegra03 »</TD></TR><TR><TD CLASS="quote">my friend just pult an ls in a 89 hatch and expects to run at most low 14 s</TD></TR></TABLE>
HAHAAA!
I take it your friend has never been racing in his life. You should tell him that his first trip to the track is going to be a reality check. He is not going to run anywhere NEAR low 14's with a basic LS swap. ESPECIALLY if all it has is i/h/e. Low to mid 15s are more like it.
HAHAAA!
