installed AC, no condensor fan, ok to run?
i put my aircon in the beater (90STD) last week or so but i have not received the condensor fan yet. Is it ok to run the ac without the fan for the mean time? Any problems that can come about with not having the condensor fan? will it damage anything?
thanks
thanks
From: I told you to wait in the truck in Texas, United States
No air flow across the condensor will create very high head pressure..
Which may cause the pressure relief valve to open, which will lose the refrigerant..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">No air flow across the condensor will create very high head pressure..
AHHH exactly what i wanted to hear
when i got home today i saw whatr looked to be smoke coming from the hood, when i opened the hood the smoke (refrigerant) was spraying out...i thought i broke something at first. fhhheeeeww
88DXCRX: the purge seems to still be open. when i try to fill my system with refrigerant, it just goes right out of the compressor. how do i close the valve?
I looked through the service manual and at my car itself..
It seems there is not a pressure relief valve used in this type system..
So,You may have blown a o-ring or possibly the compressor seal..
See if you can determine the exact location of the leakage with soapy water
or the ultra-violet dye leak detection..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">I looked through the service manual and at my car itself..
or the ultra-violet dye leak detection..</TD></TR></TABLE>
will do
will do
after looking at the compressor, i noticed a rubber plug hanging off. i plugged it back in and it did hold the pressure of the refrigerant a bit then it poppped out along with the refrig...how do i keep that plug from popping off?
itsalmostfrieday
Mar 31, 2007 06:58 PM
