distributor swap
alright im putting an 94 f22b2 in my 97 lx using the obd2 engine harness. obd1 dizzy dont match up the the obd2 harness. my questions is can i take the dizzy off the 97 motor and put it on the 94 motor? also is it possible to change the internals so i can stil rotate the housing for timing (obd1 housing w/ obd2 internals)?
in the ends its going to be run by obd1 ecu with a boomslang conversion harness if that matters...any help is greatly appreciated
DIYMIKE
Feb 23, 2007 09:06 PM
