MOMO Steering Wheel Adapter Problem - CB7 (93 Accord)
I currently have a genuine Mugen FG 360 steering wheel that I want have installed on my car, a 93 Accord LX WITH an airbag and cruise control. However, I have a problem with attaining a steering wheel adapter made for our generation Accord that would properly accomodate my car...
I heard that the MOMO 4909 Steering Wheel Hub Adapter is the ONLY adapter available... However, the MOMO 4909 is for an Accord WITHOUT Cruise Control... Is there any other adapter in which can accomodate my steering wheel needs?
Comments and suggestions will be greatly appreciated!
Thank in advance,
Omar
93 Accord LX
Thank in advance,
Omar
93 Accord LX
It's pretty simple...
Just use the non-airbag adapter...
You lose CC unless you wire it seperately and you also lose the turn signal return...but there are simple fixes for both.
but it works... I've used both the Momo/Sparco and Grant adapters for 91&earlier Accords on my 92 formerly SRS equipped Accord...
Just don't let the pencil pushers find out... I believe there is a hefty fine associated with removing the airbag on a car so equipped...
i have one that will work for you. and momo only makes the one hub. it works, but you lose your CC unless you go to radio shack and hook up a custom set up. i've seen it done and it does work. you'll have to wire up the horn anyways, so might as well take a stab at it!
have the same prb, but i have a 5 bolt grant true carbon fiber steering wheel that i want to put on my 97 accord se coupe and cant find a hub for it, except the momo. but the momo is 6 bolts instead of 5, do u guys know where i can get the 6 to 5 bolt steering wheel adapter, and how would i keep my turn signals working since i have to take out the airbag/crusie control wheel benn2k@aol.com or a.i.m benn2k
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZigenBallz »</TD></TR><TR><TD CLASS="quote">It's pretty simple...
Just don't let the pencil pushers find out... I believe there is a hefty fine associated with removing the airbag on a car so equipped...</TD></TR></TABLE>
sounds good... CC can be rewired, no problem.. but what is the fix of the turn signal return? is there a write up on this?
the turn signal works, you just leave the turn signal return spring assembly in place and remove the SRS cable reel assembly. or leave it there. it doesn't really matter. but everything works. did on my '97 until i bought my CMR hub.
pmilnes
Audio / Security / Video
Mar 24, 2004 02:03 PM
