PLEASE HELP!!! What is BEST CLUTCH for 225whp Civic SOHC d16?
Old Oct 12, 2001 | 11:39 PM
greyzone's Avatar
Default PLEASE HELP!!! What is BEST CLUTCH for 225whp Civic SOHC d16?
Wondering what is the best clutch for 225 whp d16 SOHC 1996 Civic, 2 dr coupe, 5sp.
I want something that will grab good and not slip, currently have an ACT stage one thats not cutting it, it cant handle fast shifts and is slipping bad (its not old).
What do you guys recommend? ?
Also, Will the stock flywheel do the job??
Please respond, I need help with this one.
Thanks.
[Modified by greyzone, 8:41 AM 10/13/2001]
[Modified by greyzone, 9:35 AM 10/14/2001]
Old Oct 13, 2001 | 01:22 AM
liam821's Avatar
25 Year Member
Default Re: PLEASE HELP!!! What is BEST CLUTCH for 225whp Civic SOHC d16? (greyzone)
I have a ACT xtreme pressure plate with a hybrid street disc connected to a JUN lightweight flywheel. I have a 93 civic hatch with a sohc vtec pushing 15psi (around 220 - 230hp @ the wheels).
I have no problems what-so-ever..this clutch does *NOT* slip. Its just awesome. I have about 11,000 miles on the clutch now..and when i swapped the motor a little while back the clutch looked new still. And i drive the car very very hard.
The clutch kit is the XTSS (xt = xtreme pressure plate, and ss = heavy duty street disc) and you can order it for about $400....i believe its stage 3 or 4. I dont recommend getting a 4,6 puck...its just too harsh for driving around town.
liam
Old Oct 13, 2001 | 05:11 AM
DragII's Avatar
25 Year Member
Default Re: PLEASE HELP!!! What is BEST CLUTCH for 225whp Civic SOHC d16? (liam821)
ClutchSpecialties stage III, or Clutchnet stage II
Old Oct 13, 2001 | 07:59 AM
TurboSedan's Avatar
New User
Yo fock that, get a Clutch Masters Stage 3 buddy. ACT and the other are good, but I think the CM will give you less driveline shock.
Old Oct 14, 2001 | 12:32 AM
greyzone's Avatar
Default Re: PLEASE HELP!!! What is BEST CLUTCH for 225whp Civic SOHC d16? (97CivicFerio)
Right on!
Hey, liam821, what you done to your motor for 15psi??
Also, can I keep the same disc and put in a different pressure plate?? I have the ACT Street disc, so can I keep that and put in the ACT Xtreme Pressure plate?? Also, if I do that, do I need new Release bearing and Pilot bearing ??
Keep the posts commin!! I appreaciate everyones help and opinions.
[Modified by greyzone, 9:34 AM 10/14/2001]
G3O
Mar 23, 2010 12:40 AM
strangeyelp
Oct 4, 2007 06:23 PM
ieatrice
Jul 29, 2004 07:26 AM
JDM_EH2
Jul 7, 2003 11:04 AM
