Having Problem Installing my Brakes!! PLEASE HELP!!!
This is my problem:
I installed the brake pads into the caliper and added the new Goodridge brake lines on. When I "thought" I correctly bled the brakes right, but I mite be wrong.
I can't tell if it brakes fine because My rear brake pads are hitting the rotors. Meaning I cant really move my car unless if it I accelerate pretty hard. I know You have to adjust the Ebrake cables which I did, but its still not moving.
Can someone tell me the correct way to bleed out the brakes for the ITR. I heard there is a different way to bleed when you have ABS??
Does anyone know why my rear brake pad is on?? (BRAKE light is off)
Someone help me ASAP
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM TypeR 508 »</TD></TR><TR><TD CLASS="quote">yes they are all the way in...
doesn't sound like it.. i would check it again.. that's the only wheel that's sticking?
</TD></TR></TABLE>doesn't sound like it.. i would check it again.. that's the only wheel that's sticking?
I guess maybe the only way I can check is to ... open up the stupid calipers again.. garrrr... but could that be the only way of sticking onto the rotor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM TypeR 508 »</TD></TR><TR><TD CLASS="quote">I guess maybe the only way I can check is to ... open up the stupid calipers again.. garrrr... but could that be the only way of sticking onto the rotor?</TD></TR></TABLE>
Whatever you do, it will involve taking the caliper off again...it's only 2 bolts...not the end of the world
Whoever did the brakes before me OMG like had that thing in... I had to go borrow my friends air compressor and impact that bolt GRR...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM TypeR 508 »</TD></TR><TR><TD CLASS="quote">Whoever did the brakes before me OMG like had that thing in... I had to go borrow my friends air compressor and impact that bolt GRR...</TD></TR></TABLE>
...and since you just took them off to put the pads in it will not be a problem this time, right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM TypeR 508 »</TD></TR><TR><TD CLASS="quote">I dont iknow it seems like it shouldnt be the pistons.... arrrhghhghasdg</TD></TR></TABLE>
You can either:
-take our advice, and take off the pistons
-do nothing
-complain
but only one of those has the potential of finding/fixing the problem...
You can either:
-do nothing
-complain
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo »</TD></TR><TR><TD CLASS="quote">
You can either:
-do nothing
-complain
but only one of those has the potential of finding/fixing the problem...</TD></TR></TABLE>
True. Go fix it already.
You can either:
-do nothing
-complain
I wish I could... but sitting here at school... doing my so called assignments.... I will check up on it tonight... but thanks for the advice
R_ACE1
12
Aug 16, 2009 12:53 PM
RedDC5
Feb 22, 2005 06:30 PM
