Code 6 ECU...
Old Feb 24, 2004 | 06:32 AM
90 SiR Hatchie's Avatar
Default Code 6 ECU...
I know its the Engine Coolant Sensor, in the manual its called the TW sensor. How do i go about changing or replaceing this???? Right now my VTEC doesn't work and it hard to start my car when it cold because of this. Thanx for the help.
Old Feb 24, 2004 | 06:47 AM
jlicrx's Avatar
Default Re: Code 6 ECU... (90 SiR Hatchie)
TW sensor is located on the end of the head, just in front and below the distributor - has 2 wire connector, red with white stripe and green with white stripe - disconnect connector - unscrew sensor from head and install new one - there are 2 sensors on the head, the TW and the one for the temp gauge which has only one wire - you need the one with 2 wires
Old Feb 24, 2004 | 07:01 AM
Default Re: Code 6 ECU... (jlicrx)
Kewl thanx you have a price or part number for this??
Creator
Mar 11, 2010 05:29 PM
BanEL
Jun 4, 2009 06:07 AM
Turbo EH2
Sep 29, 2006 04:03 PM
teamvirus
11
Sep 1, 2006 03:05 PM
folta2169
Jun 8, 2005 11:30 PM
