what do I need to make my ls/ dragIII safe @ 12psi?
what do I need, the drag III is on a 98 acura integra RS, I was thinging what do I need to boost safety up tp 12-13 psi??
will the drag III FMU (vortech) unit handle the fuel at that pessure!.. any and all help would be greatly apprciated..
Thanks
Thanks
I've seen 12psi with stock block/head and 370 injectors with an FMU i don't remember which disk, but I can assure you it wasn't the 12:1 that comes with the drag kit. Of course he did maybe 15 dyno runs to make sure everything was ok fuel wise, and he's had this setup for about a year now with no major problems.
get a 8:1 disk with rc 310 or 370 but u still going to need a s-afc and 12-13 psi will be ok just retard your timing or get a msd BTM
you'll probably need a 6:1 disk. Im' running an 8:1 with 310's. you'll also need a fuel controller to make it run good off boost.
chuckd05
Dec 21, 2001 03:25 PM
Tr0LL
Sep 14, 2001 10:54 PM
