zc swap plugs????
Old Feb 23, 2004 | 09:53 PM
rafimos's Avatar
Default zc swap plugs????
ok guys...i got my zc in the other day...and was going to start pinning out (for the first time) the plugs for the zc....and came across 3 plugs versus the two i was looking for....i havent compared it too much on the si...but i noticed that there was two pugs actually on the car.....and then the plug over on the exhaust cam side....http://groups.msn.com/HONDA-si...ID=13 and these are the two i nknow about http://groups.msn.com/HONDA-si...ID=14
Old Feb 24, 2004 | 03:49 AM
ek_99_SiR's Avatar
Default Re: zc swap plugs???? (rafimos)
http://www.dmoore.com/crx .all u need to know is right here
Old Feb 24, 2004 | 07:00 AM
jlicrx's Avatar
at the distributor, the Si harness has a round 7 wire connector, where on the ZC it is a square 5 wire connector - you need to swap a square 5 wire onto your Si harness, matching the wire colors to the square 5 wire on the distributor - if your engine came with a harness, you can rob the connector from it or you can use connector from a DX - you will have 2 wires left over, blue with yellow stripe and blue with green stripe - extend these wires (matching color for color) to the green 2 pin connector on the Cylinder Position Sensor on the end of the ZC exhaust camshaft - these are the only wiring changes required for Si to DOHC ZC.
Old Feb 24, 2004 | 08:08 AM
rafimos's Avatar
Default Re: zc swap plugs???? (jlicrx)
so the other round plug should plug right in?...ive gotta go check it out today....
Old Feb 24, 2004 | 04:33 PM
rafimos's Avatar
ok i just got the car on the trailor and took it to the shop, i poped the hood to figure out what wiring im goin to need...and saw the other plug i overlooked last time...its there...so im good...WOOHOO....and i added on the hp racing header today....will post pics on my msn community
99sohczc
14
Jan 30, 2016 03:20 PM
99sonicbluegsr
Sep 16, 2004 07:43 AM
lukedatwin
Aug 11, 2004 07:51 PM
VTgringo
Jun 10, 2003 04:29 PM
ScottEK
Sep 28, 2002 01:22 PM
